Diameter of Clutch master & brake master 75 TS
Posted: Thu Jan 17, 2008 12:10 am
by Dennis
After a year of struggling with the pedal feel on my 75 TS racer, I'm planning on going with a tilton or wilwood reverse mount pedal box on the new racer. Does anyone know what sizes the brake and clutch master have standard?
I have stock front calipers and giulia rear calipers (same as stock).
Posted: Thu Jan 17, 2008 2:30 am
by Daniel
You mean the standard Alfa sizes ?
Clutch master = 19mm, brake master = 22mm
Posted: Thu Jan 17, 2008 3:23 am
Dennis,
Are you using a vacuum booster and OEM brake hoses?
Posted: Thu Jan 17, 2008 4:01 am
by Dennis
no booster and I will make new lines/hoses.
Posted: Thu Jan 17, 2008 12:51 pm
If you have a dial guage, link it against the pedal box and get someone to see how much flex is in the firewall when you are down hard on the brake pedal. If it is flexing, install a brace.
The only movement you want is the fluid in the system. New braided hoses should also firm up the pedal. The rest will depend on you choice of pad materials as you know.
Posted: Thu Jan 17, 2008 10:32 pm
Which pad compound are you using?
The firewall will flex, no doubt. I still have plenty of feel in my brakes though. Old rubber hoses in the system must be replaced with teflon or similar.
Posted: Fri Jan 18, 2008 1:01 am
by Dennis
I'm using Pagid Blue all around. Pretty happy with them.
All lines are hardlines or teflon braided and yes, there's flex in the firewall. Since I'm building the new car, I thought to go with a new pedal box and move myself a little further back in the car. Been thinking about floor mount, but heared a lot of drivers complaining about their ankles with floor mount. So decided to go with a reverse mount hanging pedal setup. With the current dollar I simply can't resist.
Posted: Fri Jan 18, 2008 8:42 am
I have a better idea and I know it works.
Change pads to the Black compound in the front, they have
loads more bite and therefore you don't have to push as hard -> less flex.
Easier too.
btw, the std sizes of the MCs will work only together with the regulator in the line to the rear calipers.
Posted: Fri Jan 18, 2008 11:37 am
by Maurizio
I have some note flouting in my mind that the brake master cylinder was stepped. 22mm for the front and 19 mm for the back, can anyone confirm that?
hmmm I have thrown an leaking master cylinder in the bin a month ago, after laying useless around for 4 years
Posted: Sat Jan 19, 2008 2:15 am
by Tamariini
Daniel wrote:You mean the standard Alfa sizes ?
How about clutch slave cylinder? anyone remember what diameter is that?
Posted: Sat Jan 19, 2008 4:46 am
by PietereQ
Tamariini wrote:Daniel wrote:You mean the standard Alfa sizes ?
AFAIR clutch slave is 25,40mm. I also remember using 164 slave repair kit for gtv6 as originals were unavailable.
