escon64
oil pump racing for alfetta 200cc
Post by escon64 »
i will like to know where can i buy a racing oil pump for a alfetta 2000cc 1978
apreciate :?:
Easy. If you have an oil pump now, just recondition it with higher tolerances and get rid of the inlet screen. It's good for 80lbs which is more than enough.
A so called "racing" pump would be no different.
MD wrote:Easy. If you have an oil pump now, just recondition it with higher tolerances and get rid of the inlet screen. It's good for 80lbs which is more than enough.
Oh I disagree with you...! A racing pump will cost 8 times more !! 8) 8) :D
Maurizio
Post by Maurizio »
No experience in this one but completely get rid of the intake screen, gut feeling says wider mesh ok.
:D :D Yeah sorry Bazza. I did forget to say the 8 times cost surge would give it a status symbol as well.
Maurizio. The screen removal is just the icing on the cake but you gotta make the cake first otherwise you are wasting your time.
No, the central thing is to improve the tolerances within the gear sets within reason otherwise you can overdo it as well and give your self problems. Any good machine shop, fitter and turner mechanic should be able to do it. Got a feeling JK's latest book has a section on it.
Mine cost $150 AUD to do and yes it does make 80lbs and it's a 1978 Alfetta original pump.
Mike,seriously now...I would have said that getting rid of the screen would POSSIBLY allow a vortex or funnel to develop and suck air ?
I thought that was the main reason for the screen...
Interesting I think...anyone ?
Main reason for the screen is to keep the shit out. I've seen some badly clogged ones from all the junk.
I usually tightened the clearances slightly which improves pressure at low rpm or when oil is really hot. Doing this is very easy.
Spruell had a more powerful pump but it's discontinued.
Then there's always external pumps like the one I've bought from Weaver brothers. Didn't mount it yet though.
escon64
Re: oil pump racing for alfetta 200cc
Post by escon64 »
thank you all, at this time i am assembling my motor for the next race, i follow your advice, an i will test it Wednesday, i hope it work....?
thanks again
:shock:
TS_turbo
Post by TS_turbo »
rebuilt pimp if needed, fit wire mesh screen, restrict oil feed to head, block oil feed to lower chain pulley brass bearing(lots of hot oil pressure escapes from there big leak close to main oil gallery) :)
How do you rebuild a pimp? :D
How the hell do you get administrator rights if you don't even know how to rebuild a pimp?!??!?!??!??!?!?!?!?
:lol:
TS_turbo
Post by TS_turbo »
:wall:
escon64
Post by escon64 »
dear sir i have a mayor problem i have three pump all of them doesnt work well .....
when you mean tight it up means that i have to put some ajustment metal sheet round cutted to avoid axel moviments???? :?: :?: :?: :?:
escon64
Post by escon64 »
does anybody know if weavers brothers ltd still on bussines ????? :?:
