preparing for race july 20, 2008
Posted: Sun Jun 08, 2008 8:03 pm
i will have a race july 20 and this are the rules
TECHNICAL REFERENCE
ALFA ROMEO RACING GROUP
EL SALVADOR
ENGINE 2,000 CC........... ok
PISTONS 84 MM : 2,000 HIGH COMPRESSION 10.4 CR OR 9.1 CR
NORMALE ...................10.4
CAMSHAFTS : 105 48 0320001
CYLINDER HEAD : INTAKE 44 OR 45 MM.........45
EXHUAST 40 OR 41 MM...........40
CARBURATOR : WEBER DCOE 40, DELLORED O SOLEX......web 40
FUEL PUMP : MECHANICAL /
ELECTRIC FOR SPICA ENGINES.....mechanical
IGNITION SYSTEM : POINTS OR MAGNETICS SWITCH IN
DISTRIBUIDOR..............point
COIL : BOSCH BLUE........ok
FAN : ELECTRIC OR FAN BLADES.......electric
CLUTCH : OEM (NO METAL OR CERAMIC DISC)
(NO ALUMINUM COVER)............oem
: (NO ALUMINUM FLYWEEL)...............oem
TRANSMISION PARTS : STD GEAR BOX (NO CLOSE RATIO GEARS)
LSD : STD ZF / ALFA ROMEO........dont have
DRIVESHAFT : STD......ok
SPRINGS : PERFORMANCE SUSPENSIONS
(IAP OR CENTERLINE TYPE)......iap yellow ones
SHOCKS ABSORBERS : KONY OR BILSTEIN........bilstein
BUSHINGS : POLYURETHANE OR OEM BUSHES......polyureth
CONTROL ARMS : ADJUSTABLE UPPER ARMS.....do not have
BRAKES : SOLID DISC / CROSS – DRILLED OR OEM..... solid ones
BRAKE PADS : CARBON / METALLIC OR OEM...... metalics
EXHAUST : PERFORMANCE HEADER OR FACTORY
EXHAUST SYSTEM. ......header
ROLL CAGE : SIX POINTS........ok
SEAT : RACING SEAT......ok
SEATBELTS : RACING TYPE.......ok
WHEELS : 7 X 14 SIZE 14, 7’’ WIDE MAXIMUM
(NO STEEL WHEELS).........7X14
TIRES : BRIDGESTONE POTENZA G III TREAD WEAR 180
205 / 60 / 14 MAXIMUM..........ok
INDUCTION : EUROPEAN AIR BOX OR CUSTOM......ok
(NO TRUMPETS OR RAM TUBES)
CONNECTING RODS : ORIGINAL / OEM ALFA ROMEO........ok
ANTI – ROLL BARS : FREE
NO (HEIM JOINTS)
OIL CONTROL : NO ACUSUMP
NO DRY SUMP
NO EXTERNAL OIL PUMP
NO ALUMINIUM WATER RADIATOR
what else can i do please do your best.......fell free to advice
TECHNICAL REFERENCE
EL SALVADOR
NO (HEIM JOINTS)
NO DRY SUMP
