Turbocharged 79' GTV - Track Car Build
Posted: Sat Oct 23, 2010 5:15 pm
here is where i will document the build of my track car.
the car is a 1979 GTV, i bought the car for $700 AU and plan to build it as a track with the following:
Suspension:
-koni shocks
-bigger roll bars
-lowerd, stiffer rear springs
-new bushes
Brakes:
- volvo 4 pot calipers, and 164 vented rotors up front
- outboard rear brakes, alfa 90, gtv6, 75 front rotors and calipers mounted onto the de-deion.
- no booster, BMW mastercylinder mounted next to clutch mastercylinder.
- adjustible bias valve
- simmons v4 3-piece race wheels
Gearbox:
- standard alfetta
- with LSD or welded diff
- short-shift shifter
Car:
- fix rust
- build and install roll cage
- modifie body to fit 3" exhaust between steering rack and body
- paint white, inside, underneath, and outside
- no interior, only race buket, harness and dash
Engine:
- 2.0 ltr Nord from 83 GTV
- standard internals
- head ported
- cams
- DELCO EFI from GM re-tro fitted with a re-mapped ecu
- wasted spark, distributerless ignition
- Garrett Turbo from nissan z18
- 10psi
- 30lb per hour injectors
- equal length, stainles steel turbo header
- 3' dump pipe into 2.5 2.5" side pipe exhaust
this is a list of what i would like to happen, but we will see how it turns out
if you have any suggestin or comments of the project as it happesn please shar with me, i will be also alsking lots of questions so hopefully you smart people can help me out
Suspension:
-koni shocks
-bigger roll bars
-new bushes
Brakes:
Gearbox:
- standard alfetta
Car:
- fix rust
Engine:
- head ported
- cams
- 10psi
