Hi ,
I am after Alfetta GTV Rear coil spring lower rubber bases.
Hard to find these days , do you know where I can buy them new
Wanted. Alfetta GTV Rear spring lower rubber base
- Screen Shot 2021-10-25 at 3.22.02 pm.png (43.84 KiB) Viewed 2430 times
Re: Wanted. Alfetta GTV Rear spring lower rubber base
If you haven't found an original part by now then this might help.
Just source a thick walled ordinary garden hose. Cut a length equal to the circumference of your spring. Make a split cut along the length of the off-cut piece. Wrap it around the spring base. If it requires it, use some light cable ties to secure the wrap onto the spring base. Reinstall spring.
This is not a critical component and all you are trying to do is avoid the metal to metal abrasion and this approach will do that.
Hi MD,
EB Spare UK has got them in stock now.
