Clearing out some of my spare bits, located Brisbane and Sunshine Coast (can transfer between either). Reasonable offers on most items -
• 1 x complete 2.5L V6 including wiring, computer, afm, etc
Engine has lightened flywheel, balanced pistons & rods, rebalanced rotating assembly (crank etc), head shaved to 10:1 compression ratio, ports and intake runners smoothed. Original cast exhaust manifolds included as custom stuff re-used with 3.0 engine.
Removed due to replacement with 3.0 V6 but was running. Oil consumption high but seems to be coming through valve guides.
Comes with set of new exhaust valve guides and spare 2.5 V6 complete with computer & afm, less wiring, sump, oil pump, distributor and bell housing. $1000
• 1 x rear bumper to suit ’81 to ’86 GTV. This cost $1000 new a couple of years ago and is in PC as it was only on the car for 18 months before being removed. Needs bump strip (comes with old one that does not fit well) $500
• 1 x set of 4 wheels - 5 stud, 15x6 alloys with brand new 205/55 Toyo T1-S tyres $800
• 2 x sets GTV6 Brembo front calipers with rotors (VGC) & pads (1 set near new, 1 set 60%)
• 2 x sets 40mm DCOE del’orto carbs (116)
• 1 x complete 2L head
• 1 x 2L head, cams removed
• 4 x starter motor (3 x 4cyl, 1 x V6)
• 1 x pair rear hubs – 5 stud
• 1 x pair 23mm torsion bars (short)
• 1 x 22mm rear sway bar
• 1 x set 13mm rear springs
• 1 x set 13.5mm rear springs
• 1 x 55A alternator
• 1 x A/C compressor and mounting brackets (4cyl)
• 1 x A/C compressor (V6)
• Assorted A/C condensers (4cyl & V6)
• 1 x 90 radiator (average condition)
• 2 x 4cyl bell housing
• 2 x 4cyl inlet manifolds (116)
• 1 x set cast V6 exhaust manifolds
• 2 x 4cyl tailshaft front halves (116)
• 2 x 4 cyl airbox (116 late type)
• 1 x V6 airbox
• 3 x 4cyl sumps
• 2 x set of 5 wheels - 4 stud, 15x6 alloy (GC to VGC)
• 1 x set of 4 wheels - 5 stud 15x6 alloy (some gutter damage)
• 1 x 1.8L engine in pieces, comes with spare head (bare) and box of extra parts including 2 distributors, 3 sets cams, various pistons, rods and valves. All condition unknown
• 1 x early Alfetta carpet in GC
• 1 x bonnet from ’84 GTV, white in GC
• 1 x interior from ’84 GTV – front and rear seats, rear side trims in GC
