For sale is a complete set of six custom JE forged aluminium pistons with 100.5mm bore and with skirt coating.
They will give 12:1 CR if using 1,5mm head gasket.
Specs in the attached picture, later will post actual photos of the pistons.
Price is $950
OPTION: Around February, I could also supply sleeves and custom thickness head gaskets for a complete 3,5L kit for a very, very, very good price.
3.5L Conversion JE Pistons CR 12:1
- Alfa pistons.jpg (82.36 KiB) Viewed 2531 times
Re: 3.5L Conversion JE Pistons CR 12:1
Hi,
How much for the liners? Is the gasket readily available from a place like cometic or similar vendors?
Price for the complete kit - pistons, liners and copper head gaskets will be $1800.75evo wrote:Hi,
Head gaskets are completely custom made here in Bulgaria with the desired thickness, I am not aware and do not believe they are readily available from the big vendors.
