GlnMaurer5
ALFA ROMEO GTV6-MILANO Stay belt Timing Belt Tensioner
Post by GlnMaurer5 »
Timing Belt Tensioner Alfa Romeo 2.5 and 3.0L SOHC V6 (All)
Just Released, the new Stay Belt Ultimate Tensioner is a mechanical, semi-fixed timing belt tensioner that maximizes the utilization of newer belt technology and eliminates the shortcomings of both original Alfa Romeo timing belt de-tensioner designs. This design has been rigorously tested on the street and the race track to give you maximum protection against slipped timing belts. Set it and Forget it!
The Stay Belt Ultimate is easy to install, simple to adjust, and fits any 12V (SOHC) V6 engine used in the GTV/6 1981-86, Milano 2.5 and 3.0 1987-89, and 164 (all) 1991-93. Does not fit 24V (DOHC) engines used in 1994-95 164 models. Does not require re-use of any part of the original timing belt de-tensioner.
The Stay Belt Ultimate is manufactured in the USA, Originally designed and used by Tom Zat in IMSA Championship Racing in the USA in the 1980’s. It is Zinc plated for corrosion resistance and is backed by a lifetime warranty against defects in materials and workmanship (including the bearing).
Look !New lower price.
OR
Click here to buy
https://www.ebay.com/itm/ALFA-ROMEO-GTV ... &hash=item
