xrad
supersprint (made in Italy)
Post by xrad »
anyone use this..?
Do they fit well?
Cost: 1531$
kanga
Re: supersprint (made in Italy)
Post by kanga »
I put a set on my car, they fit perfectly and don't hang down as much as the stock ones. Best of all is the performance increase.The hardest part was connecting them to the downpipes which I think you will need as well.
xrad
Post by xrad »
any interference with the starter heat shield?
or motor mounts?
These are made for 2.5L. I have 3.0.....performance loss?
kanga
Post by kanga »
No heat shield now as it would need modification, but the headers are further away from the solenoid than the stock headers.
3ltr? You would need to compare their stock headers with the 2.5 stock headers I think the 3ltr and 2.5 may be the same, but not 100% sure.,
No prob at all with motor mounts
xrad
Post by xrad »
thnaks for info!
so far as I know there is no external difference from the 2.5 to the 3.0 until you get to the 24v. The thermostat housing is different on the Milano / 164 and somewhere (164 ithink) the starter got smaller.
I don't think you will have any problems.
TS_turbo
Post by TS_turbo »
1530 $ thats insane :shock: i made custom set for fwd gtv 3.2 and they cost triple times less :lol:
xrad
Post by xrad »
Those are very nice. I do have a welder and stainless cored wire for it. I just don;t have a way to make the plate mounts.
I will probably just stick with stock headers for now....and make sure the down pipes and rear sections are as free flowing as possible.
