dawie botha
S A 3ltre exh system
M D , looking at replacing the whole exh system from front to back.When we took motor out saw that the current exh consists of lot of peices welded together.Might as well put a new one in while were at it.Do not have limited funds and are trying to put the best one in that i can afford
dawie botha
Re: S A 3ltre exh system
Looking for that distinctly GTV6 sound ,not a lot of noice !
I now have the full CSC system, manifolds, centre section with silencer and rear section with twin tailpipes on my 2.5. I like the sound, GTV6 only more so and not too loud either.
05 Corolla daily driver
Hi Dawie
Best guys, I used them with mine - are in Edenvale - Powaflo... I have details if u PM me
Could use 38mm I'd manifolds into 50mm secondaries then into a 63mm . It seems to work best at our 6000ft altitude .
Unfortunately you won't get anyone in SA to make you a set that looks like this
- image.jpg (207.77 KiB) Viewed 11758 times
