- Alfa 75 Racer
Alfa GTV 916 2,0 V6 TB bring back to life after 12 years
Hi guys,
after another long time absent, I have made a new project for a good friend of mine. Bring back to life after 12 years sleeping in a dry garage, a very rare GTV 2,0 V6 Turbo.
This project has been startet in November 2021 and is now short time before ending with dyno day on 17th of May.
This is only a small start of that topic, updates including a lot of pictures will follow soon from beginning of work and what work I had done.
Just for information some data:
Car has now free programable ECU EMTRON SL6, Bosch 320ccm injectors, electronic boost control (max. will be 1,8 bar), Turbo out of a 164 2,0 V6 Turbo (Misubishi) with internal upgrades to get more boost and power. Suspension with KONI yellow adjustable dampeners. New fuel pump setup (pump for Lancia Delta Evo Motorsport) with internal new rubber holder for pump, wide band lambda controler Innovate. Additional readings for Boost, Lambda, Oil Temp., Oil pressure in center console instead of air nozzels. Modification of clima, clima completely out, modification of hydraulic servo pump instead of clima compressor, big brake upgrade to 166 V6 Brembo calipers with 330 discs, all arround brake pads EBC green stuff.
Repair of AZEV Type E 8J x 17 Rims with new colour GOLD with look amazing to car coloure dark green met.
So guys, updates including pictures will follow.
Greetings from Austria
Wolfgang
Wolfgang
- 20220418_231149_50%_50%.jpg (156.88 KiB) Viewed 3444 times
- 20220418_231142_50%_50%.jpg (175.87 KiB) Viewed 3444 times
- 20220418_231126_50%.jpg (251.5 KiB) Viewed 3444 times
Re: Alfa GTV 916 2,0 V6 TB bring back to life after 12 years
Thanks Wolfgang for sharing that. So much valuable information you have. Please keep us posted on progress . This engine is also used in my friends GTV6 so there is loads of interest on this set up !
- A6DE8329-0D59-495E-B3C4-07344692B479.jpeg (141.59 KiB) Viewed 3436 times
Fantastic project Wolfgang. thanks for posting this on this forum, keeps it interesting and hopefully will continue to keep this forum alive.
- Alfa 75 Racer
Hello Zamani, nice hearing from your side, that you love my project.
During main assembly there is not that much to write, exept there were a lot of damaging because car was only standing without moving ...
Just a small list:
timing belt (last change 25.08.2010 !!!)
wheel bearings
shock absorbers
all brakes
clutch cylinders
brake main cylinder
all sealing rings
fuel pump
all rubber parts arround fuel pump were like silicone and glueing everywhere, also in the tank (was almost empty)
etc, ...
Here are some pictures how I got the car (delivered on a trailer) and the start of disassembling and working on some parts to prepare.
Just a small list:
wheel bearings
shock absorbers
all brakes
clutch cylinders
brake main cylinder
all sealing rings
fuel pump
etc, ...
- Picture 5.jpg (188.72 KiB) Viewed 3422 times
- Picture 4.jpg (110.76 KiB) Viewed 3422 times
- Picture 3.jpg (145.89 KiB) Viewed 3422 times
- Picture 2.jpg (122.5 KiB) Viewed 3422 times
- Picture 1.jpg (137.94 KiB) Viewed 3422 times
- Alfa 75 Racer
Someo more pics of disassembling.
Cheeres
Wolfgang
Cheeres
Wolfgang
- Picture 6.jpg (140.64 KiB) Viewed 3422 times
- Picture 7.jpg (168.12 KiB) Viewed 3422 times
- Picture 8.jpg (169.36 KiB) Viewed 3422 times
- Picture 9.jpg (155.34 KiB) Viewed 3422 times
- Picture 10.jpg (195.81 KiB) Viewed 3422 times
- Alfa 75 Racer
more pics !!!
- Picture 11.jpg (207.94 KiB) Viewed 3422 times
- Picture 12.jpg (190.91 KiB) Viewed 3422 times
- Picture 13.jpg (137.75 KiB) Viewed 3422 times
- Picture 14.jpg (128.41 KiB) Viewed 3422 times
- Picture 15.jpg (162.88 KiB) Viewed 3422 times
- Alfa 75 Racer
It was really hard to get off that bad soft paint of center console and middle console, ... best way is to take ACETON, but not too long on the surface.
Better to wash it with an old piece of a T-shirt twice or tree times. At least when the surface is dry, take a 320 wet sandpaper and finish the surface for prime painting. Before painting it´s important to clean the surface with anti silicon. For first and second painting I´ve taken a normal black matt spray and then after approx. 10 minutes (don´t let it dry complete !!!) I´ve painted two layers of 2K clear coat (very good quality). Then the result will be perfect as you can see on pictures.
- Alfa 75 Racer
pics
- Picture 16.jpg (151.73 KiB) Viewed 3422 times
- Picture 17.jpg (153.19 KiB) Viewed 3422 times
- Picture 18.jpg (171.12 KiB) Viewed 3422 times
- Picture 19.jpg (181.52 KiB) Viewed 3422 times
- Picture 19_1.jpg (204.98 KiB) Viewed 3422 times
- Alfa 75 Racer
more pictures of disassembling the car
- Picture 21.jpg (199 KiB) Viewed 3420 times
- Picture 22.jpg (188.6 KiB) Viewed 3420 times
- Picture 23.jpg (162.85 KiB) Viewed 3420 times
- Picture 24.jpg (151.28 KiB) Viewed 3420 times
- Picture 25.jpg (191.47 KiB) Viewed 3420 times
- Alfa 75 Racer
It is to say, that the car had already a very old aftermarket HALTECH E6S on board, so more complicated to find correct drawings of harness and pin out diagrams of ECU (Thank´s to Haltech download center special for old ECU´s and parts.
One of problem was, that there was not a 60-2 tooth supply on crank pully so I had to find a good used one ore take off the Haltech disc where some magnetics north and south pole were glued in. Also I have to change crank sensor, because Haltech sensor works only with that ECU.
At least I could solve all that problems !
During disassembling I´ve found out that on Cyl. 4 exhaust side there was broken one stud for exhaust manifold. It´s always tricky to get out that broken things ...
- Picture 26.jpg (197.9 KiB) Viewed 3420 times
- Picture 27.jpg (166.8 KiB) Viewed 3420 times
- Picture 28.jpg (197.2 KiB) Viewed 3420 times
- Picture 29.jpg (187.01 KiB) Viewed 3420 times
- Picture 29_1.jpg (186.84 KiB) Viewed 3420 times
- Alfa 75 Racer
more pics ...
hope you enjoy my documentation so far ...
Cheeres Wolfgang
My friends here in Austria call me "Dottore Alfa", soundes funny, but makes me very proud.
Cheeres Wolfgang
- Picture 30.jpg (119.34 KiB) Viewed 3419 times
- Picture 31.jpg (180.44 KiB) Viewed 3419 times
- Picture 32.jpg (198.38 KiB) Viewed 3419 times
- Picture 33.jpg (160.2 KiB) Viewed 3419 times
- Picture 34.jpg (130.59 KiB) Viewed 3419 times
- Alfa 75 Racer
and more of them ...
- Picture 35.jpg (131.62 KiB) Viewed 3419 times
- Picture 36.jpg (174.41 KiB) Viewed 3419 times
- Picture 37.jpg (212.05 KiB) Viewed 3419 times
- Picture 38.jpg (192.71 KiB) Viewed 3419 times
- Picture 39.jpg (201.14 KiB) Viewed 3419 times
- Alfa 75 Racer
Look at picture no. 40 .......
My friend was lucky that there was no problem ... shim oil pump gear was almost gone, have found all pieces in oil sump-
- Picture 40.jpg (170.96 KiB) Viewed 3419 times
- Picture 41.jpg (125.56 KiB) Viewed 3419 times
- Picture 42.jpg (211.16 KiB) Viewed 3419 times
- Picture 43.jpg (178.64 KiB) Viewed 3419 times
- Picture 44.jpg (179.49 KiB) Viewed 3419 times
- Alfa 75 Racer
OK guys, that´s it for now, more pictures will follow.
For these cars, 916, 156, I’m going to move towards more electrical accessories. For example electro-hydraulic PS pump, maybe electric AC compressor and move them into the boot. Although the GTV has a small boot to begin with. The battery is something I’d like to move into the boot too. All I want in the engine bay is the alternator.
