Page 3 of 3
Re: Alfa GTV 916 2,0 V6 TB bring back to life after 12 years
Posted: Mon May 16, 2022 12:01 am
by Alfa 75 Racer
more pics, ...
pic 68_24.jpg ... MARRIAGE !!!
Posted: Mon May 16, 2022 12:04 am
by Alfa 75 Racer
more pics, ...
pic 68_27.jpg ... solenoid for electronic boos control via potentiometer located in middle console.
Poti will give a signal to ECU, so it knows how much boost and then via MAP Sensor and WIDE BAND LAMBDA adjustment of injection and ignition.
pic 68_29.jpg ... had to make an adapter for fuel pressure sensor on lath ou of a squared aircraft aluminium bar.
Posted: Mon May 16, 2022 1:05 am
by Alfa 75 Racer
more pics, ...
Posted: Fri May 27, 2022 3:52 pm
by KevinR
How has the final dyno session gone? What type of oil are you using in that motor ? Do you have a reservoir for cold oil to run back into turbo once you switch off . I saw this on a some factory Alfa turbos in SA
Posted: Wed Nov 23, 2022 4:12 pm
by KevinR
Hi Wolfgang
Hows the project coming along ? I believe you have made some headlight upgrades. I do enjoy this thread as so much info to be gained from your engine mods which is this engine has been used a few times in conversions into the 116 GTV6.
