This setup uses 2003+ 156 GTA 330x32mm discs with widened (4mm) 166 v6 calipers. Discs have the center hole enlarged and wheelstuds fitted, no spacer is used between disc and hub.
![Image](http://i51.tinypic.com/659y8k.jpg)
![Image](http://i53.tinypic.com/k20ni8.jpg)
![Image](http://i54.tinypic.com/5ebl91.jpg)
![Image](http://i53.tinypic.com/2jesolf.jpg)
![Image](http://i52.tinypic.com/wbzypu.jpg)
How thick is it?It's just a flat piece of steel,
In dutch:How thick is it?
materiaal staalplaat, dikte 10 mm
Great! Keep me postedkillaz wrote:Jose_76: I'm doing 300mm conversion and I have Azev 16x7.5' too (ET:30)... I'll inform you about fitting. Regarding "ears" - yes, you'll have to cut them. Just yesterday tried to fit them without cutting, but no way - same thing for 305mm.
