ok, also you can fit different synchro rings.ingegnere wrote:Barry
I don't want to be off topic, but you're right. The idea is to make new sycros. (I wrote more about this on Transaxle fix??!!! topic) The method you've suggested sounds great! The only problem is I don't know yet where do we have repair shop like that, but I will ask. Thank you for the info!
Tectoteam, thanks for you as well.
there is different models.
the first, 'soft' used on first gtv6 and on others models.
an others with a yellow color circle tip that are a bit stronger and meka the job as well as the 'soft'.
the weak syncrho is:605-16446
the 'hard' syncrho is:605-22434
you can also find the reference in the eper software that are used by the alfa shop.
well, next time i see the friend ill ask him for.Maurizio wrote:Perfect ( www.matweb.com ) this is alway my first and best place to look first! But couldn't find you 2017 .............tectoteam wrote:![]()
well i find some info.
my 'french' AU4G it's : 2017.
the specs: http://www.matweb.com/search/SpecificMa ... um=MA2017O
and for the famous 7075 t6 (AlZn5.5MgCu 165 Hv , you spoke maurizio)
the specs:http://www.matweb.com/search/SpecificMa ... m=MA7075T6
looks like the au4g drives me on a wall
Key Words: Aluminium 2017-O; UNS A92017; QQ-A-4300; QQ-A-222/5; NF A-U46 (France); MIL-R-430; ISO AlCuMgSi, CM41 (Canada); AA2070-O
http://www.matweb.com/search/SpecificMa ... m=MA6082T6 must be available at every self respecting machine shop.
just hope this 6082t6 dont be awesome costy...
its on way.......
