Jose_76 wrote:Jim, proportions are just the point. That's just what I've taken care at while thinking of the right rear discs.
Standard brake discs on the GTV6 are Front 269mm and Rear 250mm. That makes a 1,076 to 1 ratio between axles.
Fitting front 305mm discs and rear 281mm, you have a 1,085 to 1 ratio, so you have proportionally more braking power at the front than stock.
And that would be just keeping the standard calipers!! With the 4 pot calipers you have even more braking power at the front than stock.
joze.....
take care for the rear.....
too bigger disk will never comes hot and squizze a lot, the after.
they are near from the floor.
they are heavier.
big mods for rear calipers and mounting points.
in france there the gtv6 had run and win a lot from the past trough the eigthes against BMWs...
the balance for a 270hp car
front 284*28 4 pot(2* the brembo oem) + air ducting.
rear vented rear in 255*24 in 4 pot....
so this translate to lots of braking.... in hard issues.
so you can let the 250 mm disk for sport or track days.... however if you encourted some heating problems, after tries air ducting, go to SZ/RZ (or any 250-255) vented (20-24mm) rear disc and caliper spacers...
BUT.......!!!!!!!!! dont forgot something.......if you let the gtv6 rear brake pressure limiter, you never !! never had to power up rear brake.
the rear limiter is .......very limiter.....! it will never cause a rear brake heating failure..(with good pads..)
if you fit a adjustable rear limiter....consider that the minimum limit is far(bigger) from the oem limiter. and this will give you good rear clamping, then at this moment if you fit....280mm or more.... this will become undrivable, oversteering on braking comings.
over all......the brake pads.....is from far a very important thing.
