How do we bleed our brakes?
Posted: Mon Jan 09, 2006 7:28 pm
Do you use air pressure from the top-up tank, suction from the bleed nipples?
Sequence, front first, rear left?
Clutch bleeding?
I personally have an assistant in the car that will pump the pedal. Then hold the pedal down whiles I open the nipple witch is connected to a transparent hose so I can see if any air is present, then close it before the stroke of the pedal is reached.
I do the back first, working on the outer piston first then go to the front.
Seem to work for me
Clutch bleeding?
Seem to work for me
