Hello everyone!!
I just got myself a nice set of the good old Ronal Turbo wheels (4stud, 27offset) but when i tried to mount the front ones i realised to my despair that it is impossible to clear the calipers (i have gtv6 Brembo calipers with gtv6 discs drilled for a 4 stud pattern).We tried to use some spacers but the inner vertical 'nerves' of the wheel were fouling the caliper even with 8mm spacers!! I know that these wheels when they are of the 5 stud pattern pose no problem with the gtv6 calipers...
Have you any suggestions? I do desperately want to fit the wheels which i was searching for ages... Will Brembo Reds (with appropriate brackets) clear the wheels or not? All i need as i see it, is a much swallower caliper (without the bulbs of the gtv6 ones...)
In need of immediate help!
X
