How to disable brake and antilock warning lights on Milano
Posted: Wed Mar 21, 2007 7:43 am
by AlfaBeta
Hi gang,
I know this is the gtv6 forum but you guys are really knowledgeable about this stuff. I'm in the process of converting my Milano to non-ABS and I have a question. Is there a way to disable the brake and antilock brake warning lights? These are going to be lit once the non abs system is installed. I know for the washer fluid level light for example you just short out the leads on the connector. I've done this and it worked ok.
thanks
AlfaBeta
Posted: Fri Mar 23, 2007 9:31 pm
...er how about taking the bulb out ? :idea: :D
Posted: Sat Mar 24, 2007 5:04 am
by x-rad
ohhhhh.........that's why it say's GURU next to your name, MD :P
Posted: Sat Mar 24, 2007 1:54 pm
Thanks x-rad. Wish I had the brains to go with title.. :)
Posted: Sat Mar 24, 2007 4:08 pm
by AlfaBeta
Hi guys,
Thanks for the reply. For the ABS light you could just pull the bulb, but the brake light is part of the ARC. I think I can just short the brake pad sensor wires though, this should disable the brake warning light on the ARC.
thanks again
AlfaBeta
