Sorry if this turns up twice. I thought I sent it but it has not appeared yet.
I have the pedal box out as the booster died. Got a Milano replacement.
I would really like to replalce the plastic spacer between the brake and clutch pedals as there is a lot of slop compared to the Milano pedal box that came with the booster.
Problem is the roll pin that secures the pedal beam. How the heck is it removed? Heat and tugging on it?
I can probably get a thin drill down through the center of the pin and drill through the box, open up the resulting hole and press the pin all the way through.
Any thoughts?
GTV6 Pedal Box Rebuild
Jef
www.motozane.com
www.motozane.com
