Alfa GTV6 NZ
Performance rotors from Centreline
Post by Alfa GTV6 NZ »
Hi guys,
I tried searching but could not find the answer.
Is anyone using the performance slotted and drilled rotors from centreline?
what are you thoughts over the standard rotors?
Also anyone tried the IAP ones?
Thanks in advance.
Karl
Re: Performance rotos from Centreline
If you are talking about the Gyro disk conversion that Centerline sells, then yes, I have used it, and it's darn good. If you are asking about drilled and slotted stock rotors, then no.
Alfa GTV6 NZ
Re: Performance rotors from Centreline
I was looking at just getting the rotors not the set.
Anyone else had any experience with these?
