GTV27
rear brake adjusters
Post by GTV27 »
Anybody know of where to get a tool to loosen the locknut on the outer adjuster while allowing allen key access to the adjuster? Am thining of cutting a 17mm socket in half and welding on an arm, but thought there might be an easier option out there somewhere?
thanks in advance
Jason
1983 GTV6 2.8 litre
Re: rear brake adjusters
Hi Jason,
Never seen a tool for the job off the shelf. Made one exactly as you say about 15 years ago and been using it ever since. A cheap socket will do as the tension is small. I just welded it onto a 150mm long piece of 12mm square tube after grinding down. (keep it cool during the grind so as not to change the temper).
GTV27
Post by GTV27 »
DIY seems to be the winning ticket at this stage.
Jason
1983 GTV6 2.8 litre
Zagato
Post by Zagato »
I use a recessed ringspanner that has been ground down in thickness.
GTV27
Post by GTV27 »
that's a good idea - probably have some old offset ringspanners that might do the job with some grinding and bending...
Jason
1983 GTV6 2.8 litre
Zagato
Post by Zagato »
Yes they do, you just have to grind the ring a bit thinner, i believe the size is 17mm?
GTV27
Post by GTV27 »
yes 17mm and the allen key is 5mm
Jason
1983 GTV6 2.8 litre
