Jose_76
Difference between SZ vs GTV6 brakes
Post by Jose_76 »
We all know here that the front SZ discs (284x24mm), when available, were a direct replacement for the standard GTV6 ones (269x22mm). I've also read that the front calipers were the same 2 piston Brembos as in the GTV6, so:
Can anyone confirm that the masses/spindles were different? I bet that this is the point as the calipers should be bolted about 8mm away, but I've checked the ePer and both the calipers and spindles show a different reference.
Thanks!
'84 Red GTV6 3.0
Re: Difference between SZ vs GTV6 brakes
I think I read somewhere that indeed the SZ/RZ spindles were different than GTV6/ 75 ones. I seem to recall they where dropped spindles so I guess a caliper mounting point difference could be possible too.
