I see what you mean Mats. You are correct. Using the AC to cool the charge as it comes in just wouldn't work. It would take a HUGE AC compressor and it would rob too much power when you turn it.
The method we are talking about simply cold soaks the intercooler during off boost driving so that's it's way below ambient temperature (like 40 or 50 degrees below) when the boost turns on.
- Giulietta24vTT
Very nice Barry!
I used both intercooler and Chargecooler on a 2.0 turbo Fiat\Lancia engine few years ago, I used 2 electric (renault Clio william's) heating recirculation pumps in row and a bmw 528 air con radiator with 2 Spal 9" push fans , it worked brilliantly....
That was a Subaru 2.5T legacy chargecoler that I chaged its air entrance direction.
- Chen_S_Fiat_Coupe16VT.JPG (42.01 KiB) Viewed 9576 times
- DSC00780.JPG (199.1 KiB) Viewed 9578 times
Chen S
ex Giulietta 24V Glenwood TT.
Hah, this dates back to multiple stage supercharging on power gen and aircraft engines... an "Intercooler" was a chargecooler placed between stages of compressors, an "aftercooler" was a charge cooler placed between the last compressor and the engine.zambon wrote:ok, thanks for clearing that up.
I think that the term aftercooler does still circulate. I have seen it floating around often in my search results. (I have been trying to read about this sort of thing).
Peltier cooling charge air?
Has anyone heard of, read, calculated on, seen or done a peliter installation?
You could, perhaps dramaticaly, increase cooling efficieny in a watercooled system with peltier-elements.
// Wyatt Eliasson
// Wyatt Eliasson
A peltier element is a thin set of semiconductors which use a quantum physical effect of heat transportation. Its a heat pump run by electricity with no moving parts.
Its very simple to mount and understand. 2 cables, if you apply current one way it moves heat it the direction of the current.
It also generates heat on the side that it moves heat too.
They are effective when the temperature diffrence if big, say 30-200 C.
They are also very light weight. But expencive.
Atleast in a setup like this.
In this case you would use it between the water and watercooler to increase the amout of heat transfered.
Or, between the charge air interface to the water.
They can also be stacked to increase the heat difference but int this case the actual heat flow increase would be more intresting.
They could be a way to use a smaller radiator (lesser weight) or the same size with better output.
Wyatt Eliasson
Wyatt Eliasson
Geesus I dunno about this, it sounds like a miraclegesus wrote:A peltier element is a thin set of semiconductors which use a quantum physical effect of heat transportation. Its a heat pump run by electricity with no moving parts.
Wyatt Eliasson
It just that it sounds like some of the "fuel saver" theory stuff
Isn't this for computer chips etc
I have no reference of it being used in cars yett. Its popular in mobile coolers and computer cooling.
If youve seen the minifridges with a 12V car connection, those are peltier cooled instead of compressor cooled.
So, no, but I wounder if you have any numbers on how many watts need to be transported to make it any fun.
//Wyatt Eliasson
//Wyatt Eliasson
