torrente
Air Flow Meter Adjustment
Post by torrente »
Gimme the skinny, I put on the large bore Bosch AFM with the L-jet and need the real deal on adjusting spring tension. Now, I`ve tried Harris` idea on the voltage coming off of the O2 sensor and cannot seem to make a difference with this. Is it possible to use a lean-drop technique or a maximum idle to get this thing dialed in. Seems to be running rich? Please reply.
torrente
Here is what I`m dealing with!!!
Post by torrente »
Need expert advice on this AFM adjustment seems to be running a little rich. Ciao.
81GTV6
Post by 81GTV6 »
WOOO look at that bling bling!!!
I know Greg Gordon's site has information on how to adjust the AFM to get the mixture right: http://oldebottles.com/italiancars.htm
Should be on page 3, near the bottom.
Jacob Ricciotti
'81 GTV6 3.0
'81 GTV6 Track car
'91 164S daily driver
