Michael: I have never installed a 24valver so I don't know first hand how complex that swap is. My experience is that swapping in different types of motors is usually a lot more complex and time consuming than expected. Swaps also tend to devalue the car in the long run. Right now that's not a factor with transaxle Alfas, but it could be one day. Not long ago lots of owners of early Z28s swapped out thier 302s for 350s. That swap made sense, more displacement, more power, and it bolts right in. Now a Z28 with it's original 302 is worth an insane amount of money.
The supercharger unbolts.
In the case of this car installing the supercharger was easy. It's the intercooler, pipes and especially the SDS system that took the time. None of this was super difficult, just time consuming. The dashboard also took a lot of time. My father says he isn't doing that dash arrangement again. From now on if the customer wants gauges he will have to have them somewhere else, perhaps by sacrificing the ARC unit.
I will be selling kits again. I only stopped because the machine shop I used in Texas closed down and with my pending move to Oklahoma and the SuperRedVerde project in my shop I didn't have time to make more. Now that I my move is complete a new shop in Tulsa will be doing the machining. They are cutting the kits out on a water jet machine which should be really nice.
Hi Grant, The SZ spherical bearing is far superior to a poly bushing in the same location. We actually tested a poly bushing on my dad's car during this project to determine which would be better. We have tested 4 options here, stock, poly, a poly/rubber hybrid, and the SZ bearing. There is just no comparison, the SZ bearing is the way to go. My second choice is the poly/rubber hybrid I made myself, then the stock bushing. The poly unit didn't perform properly.
When I drove the car it didn't really have enough tire on it to take advantage of the suspension mods. Once it was delivered, the owner installed 17" rims with some sort of high performance street tire. Both he, and my father report the handling is incredible. My father says it's the best handling car he has ever driven. The owner is very happy with the cornering and just drove a new 350Z for comparison. He felt the new Z car wasn't even in the same league.
Greg,
www.hiperformancestore.com
Greg,
I probably will supercharge a 24 valver at some point. Right now there are three big stumbling blocks to that.
1. 24 valve motors are really rare in the U.S. and I don't have one, let alone have one in a car.
2. I am 100% certain I can boost power with the 12 valver high enough to destroy the transaxle. This means that for my personal cars I don't want to bother with the complexity of a 24 valve swap for extra power I can't use in a practical regular use car.
3. The Spider supercharger kit is taking all my time right now. It's the priority. I can't stand driving the Spider with the stock motor, it's just so slow.
I run the poly DeDion bushing from Performatek on the Milano race car and haven't noticed any issues. Can you elaborate?Greg Gordon wrote:The poly unit didn't perform properly.
No definite answer for that one. I have seen two broken pinion gears and one broken first gear. All of these were broken by STOCK 2.5s.
I think with careful driving a stock driveline can handle around 300rwhp. That's just theory. Greg Armstrong told me his Milano went through about one gearbox a year. He never had it dynoed but I figure it's around 300rwhp. I read that the famous red South African Twin Turbo racer Dawie Devillers built ate gearboxes like crazy before it was changed to a front mounted box. I seem to remember it has 400-500 flywheel horsepower depending on boost level. I could be wrong about that.
I shall quote from the Glenwood Alfa site:
"All this power has created two major problems for the Glenwood team. The first is that the car shreds its 16-inch Dunlop racing slicks in a disturbing manner and 17-inch tyres became a necessity. An even bigger problem is that the sheer power has destroyed all the team's original Alfa gearboxes and to overcome this difficulty, Dawie fitted a front-mounted Getrag gearbox."
These problems related to a race car that was run at either 300rwhp at 14.7 pounds of boost or 400rwhp at 19+ pounds of boost.
I don't know what the current Glenwood normally aspirated motors put out. I seem to remember a dyno chart on the Alfabb with 301rwhp. I think that motor was a 12:1 (probably on race fuel) 3.7 24valver. With carefull driving that should be OK. It might be best to ask JJ or Jes as all of my facts here could be wrong.
