Posted: Sat Jan 20, 2007 1:39 pm
Scott, you're starting to get a handle on it.
Greg, essentially the analogy with ambient temps and water condensates is not where this issue is. High temperature acid dew points and ambient temp water dew points are miles apart.
If you have the time and for others that have an interest in this subject, please read material in the following links to help you get your head around it. The examples provided are centred around industrial combustion processes and stacks but the fundamental issue of combustion, the formation of acidic gases and the effects of acid dew points on metals is the same as it is for cars.
http://www.hbscc.nl/publications/56%20c ... ingscc.htm
http://www.landinst.com/combustion/prod ... wpoint.htm
http://www.bycosin.se/Deposits_more.htm
