Page 3 of 7
Re: New V6 3liter 12v pistons.
Posted: Tue Sep 16, 2008 11:55 pm
by Maurizio
![Mr. Green :mrgreen:](./images/smilies/icon_mrgreen.gif)
ok, but why start a lesser design...so who starts the TS (turbo/supercharged) project.
And forget about the 6 cil there are people who race lorries.....
Posted: Wed Sep 17, 2008 1:10 am
by Jim K
Mau, your problem has been solved right there in Holland by 90-95%! Why don't you call VdWereld (spelling??) and see what refinements you want to make? I'd be happy with a TS with specs like the ones he sent for the book! 217hp, 32kgm with std 10:1 CR?? They didn't even open up the engine!
BTW, where's the right thread for all this %&*#!!??
Posted: Wed Sep 17, 2008 5:11 am
by killaz
Maybe this topic could be splited into two usefull topics instead of one confusing? I4 discussion could really open some new horizons.
Posted: Wed Sep 17, 2008 3:01 pm
by Greg Gordon
Maurizo:
I don't understand your "why start with a lesser design" comment. I could argue that every Alfa engine is a lesser design at this point. I suppose I could shoehorn in a 2JZ, that would be superior to any Alfa production engine.
I am supercharging the Nord engine because that's what's in the all the Alfa Spiders in the U.S. and I am working on an Alfa Spider supercharger kit.
Posted: Wed Sep 17, 2008 10:11 pm
I had a head all ported and done with stainless valves so the choise was already made.
![Wink ;)](./images/smilies/icon_wink.gif)
My 16v will stay buried for now.
L850 anyone?
Posted: Wed Sep 17, 2008 10:54 pm
by Maurizio
Greg Gordon wrote:Maurizo:
I knew I would start this with my comment, just poking around.
What I meant is that a TS combustion chamber is nicer to start with as a nord.
Á nord looks cheaper to upgrade wrt to a ts (when talking NA engines).
I guess Nord vs TS for build costs with forced induction that doesn't matter/is the same. Greg I like your concept, just add on to an standard engine! Pity your market has no ts.
I stick to the alfa's. If I would change brand and had the budget, I would buy a bmw 1series and slap r-tires on and ready to go! ![Twisted Evil :twisted:](./images/smilies/icon_twisted.gif)
For now I keep improving my driving/suspension/car in the handling department.
When everybody else is driving circles around me just because of a lack off power and talent...... and when I find the budget, forces induction is the way for me and my trackday TS.
Posted: Wed Aug 05, 2009 1:16 pm
by kevin
Back on topic , how do i get in contact with seller of the pistons advertised for v6 3.0 12v on this forum. (10.5 CR).
Posted: Wed Aug 05, 2009 3:07 pm
by Zamani
JK's new dome shape or Paul Spruell (
http://www.paulspruell.com/) flat top pistons? Both 10.5:1.
But JK's also have really short skirts I think (I think he was thinking of REALLY SHORT skirts for something else, but accidentally wrote it in the piston specs
Posted: Fri Aug 14, 2009 12:54 pm
by slyalfa
Mats wrote:First time I've ever seen a radiused crown from JE, nice.
Not to sure about coating on the crown though, why did you opt for that? All I heard about it is that it makes the engine very sensitive to pre-ignition without any real gain in performance.
is it Pre or post-detonation?
I could see a lot of knocking if the timing was not reset. I think it makes for a faster burn. And if that is the case then you get more power with less timing.
but just drop them in and not change anything I could see it knocking.
now if it is pre or self-ignition then we all will agree that is very bad.
Posted: Sat Aug 15, 2009 10:42 pm
by kevin
I would like to try rebuild a 75 3.0 12v motor for track day but its the first time I have seen this type of engine as we never got these here in South Africa, we only had the autodelta convrsion 3.0 for the old 2.5 motor so thes eparts are not the same.(different dome shape due to cylinder heads). I need pistons with max 10.5 cr due to our fuel here. Also would like to know if alfa made and differnt version of the 3.0 75 with higher cr ratio that are off the shelf parts.
Im not sure at this stage where I am going to order any parts for this engine from ?
There will be some budget on this motor in terms of pistons as impoting here is frightening(Rand / dollar) thats why doing 24 v conversions is much cheeper.
Posted: Sun Aug 16, 2009 12:46 pm
by Giuliettaevo2
the 164 QV(200bhp, higher comp/different cams/ larger AFM/ different programming, best 12v engine IMO) model had higher compression, as did the SZ/RZ. The 91/92 model 75 QV with Motronic could have the higher compression but i'm not sure...
Posted: Sun Aug 16, 2009 1:21 pm
by kevin
Thanks for info .
Posted: Sun Aug 16, 2009 5:12 pm
by Zamani
Kevin,
If you already have a 75 3.0 engine, why not just shave the heads? You will get 10.5:1 without having to deal with importing anything. Then for adjusting the cams, just do what JK did with the pulleys.
Posted: Mon Aug 17, 2009 1:03 am
by kevin
Z, the motor is shot , ie it needs to be redone so i would like to not do any skimming at this stage. Most of the stuff i would like to do in stages. If I dont come right then maybe I might have to this.
Posted: Mon Aug 24, 2009 9:26 am
by Jim K
Kevin, You can get similar 12V pistons without any coating and fuller skirts from A.Walter (Scuderia del Biscione, France)
I think they're ~2000Euros
You can mill the pi$$ out of the heads, I've taken 1.6mm off. Converting to 'cheapo' adj. pulleys is very easy.
My suggestion is to use the Motronic system with the 60-2 crank pulley (even order this part new as I did for ~60Euros a few years ago). If you have aftermarket ecu's for free (or almost as you do down there) go for them. Isn't
anyone the least curious about how well a remapped factory ecu will work? Come on,
not everyone has an interest in profit
all the time!!
All engine ancillaries are the same as in the 2.5liter V6.
You can use the same exhaust headers with the 2.5, ie CSC or your own fab. There are lots of cams available, your buddy Barry has a couple of
very good ones he has tested. Catcams has a few very good profiles also, P/N 1030321 and 1030322. Get a good set of valve springs from Centerline or Spruell, a set of THS rods, lighten the flywheel to ~8kg, balance everything and you can easily go over 7400+ depending on the heads.
Aren't you tired of them big-bore 24v jobs? Can't anyone cut it with
std factory capacity engines down there
