Page 7 of 13
Re: Post some vids boys!!
Posted: Mon Aug 23, 2010 12:13 am
by GarthW
Awesome vid, really enjoyed that footage!! That little 33 flies!!!
Sounds awesome FedZ, well done, and thanks for posting..!!
Posted: Mon Aug 23, 2010 3:25 am
by fedezyl
Thanks!! Got to work on the chasis and brakes now! thinking about coil overs and wilwood calipers, I want to keep the 14in rims though...
My brakes were fading after a few laps even though I put some brake ducting
Posted: Thu Sep 09, 2010 6:50 pm
by GarthW
Took a couple of vids today, nothing much, but just going for spin around the neighbourhood. Turn up the volume!
http://www.youtube.com/watch?v=QNxb_RhjOSE
http://www.youtube.com/watch?v=fJsZy2EbBTk
Posted: Thu Sep 09, 2010 8:19 pm
by MR2 Zig
Garth, you might want to keep a supply of those tires handy....looks like you'll need them
Posted: Thu Sep 09, 2010 9:46 pm
by GarthW
Yeah for sure Ziggy. They smelt good thats for sure.
Haha.
Posted: Mon Sep 27, 2010 8:05 am
by Zamani
Check out this setup
http://www.youtube.com/watch?v=_cQ6BL_BXK0
Interesting way of implementing the S/C.
Posted: Mon Sep 27, 2010 10:42 am
by Greg Gordon
That's a lot of impressive carbon fiber work. That supercharger set up must have been a lot of work as well, all that carbon fiber, dual throttles etc.
Posted: Mon Sep 27, 2010 12:58 pm
by Zamani
SO he wants the N/A route to be totally S/C free it seems, hence the magnetic clutch. Is there a real big benefit to disengage the S/C as opposed to your bypass setup Greg? The Kompressor Mercs, do they have a bypass and electromagnetic clutch too?
Posted: Mon Sep 27, 2010 6:46 pm
by Greg Gordon
The clutch is sort of a pain to use. It limits the amount of power you can put into the supercharger, and it's another component to worry about. G.M. Ford, Jaguar, Mini, and most of the others shut off the blower with a bypass valve. Mercedes uses a clutch. The advantage of the clutch is it allows the engineers to program it to come on or off under very specific conditions. The bypass valve operates based on power demands.
In this application the clutch has the advantage of making the supercharger quiet, although with the throttle on the intake side that would be a moot point.
Posted: Mon Sep 27, 2010 11:07 pm
Fuel economy?
Engineering curiosity?
Posted: Tue Sep 28, 2010 8:24 am
by Greg Gordon
I don't think fuel economy would be much different either way. According to Magnuson the 112 cubic inch blower only uses 1/3 of a horsepower to drive at highway speeds with the bypass valve open. It just doesn't take much to spin hollow alloy rotors that are not compressing any air.
With a clutch system under the same conditions, I don't know what the power drain will be, but it won't be zero. The pulley still spins, and the rotors still spin due to air passing through them (although in the car in the post above they won't spin due to the throttle setup). In any case, the difference is minimal.
Posted: Sun Jan 16, 2011 5:36 am
by Melvivio
Even though it is winter, it was a very nice day for driving, and so I did!
Enjoy guys, and I'll promise to be more active here
http://www.youtube.com/watch?v=ATMn9L1zfWU
Posted: Mon Jan 17, 2011 1:55 am
by GarthW
Your gtv6 is beautiful!!!
Good work with the 3.0 24v, looks great in there.
Very nice and enjoyed the video, thankyou.
Posted: Mon Jan 17, 2011 4:30 am
by fedezyl
Very very nicee!! made me want a Gtv6 right now to put that 24v I have here! The only problem is I need to import it! are those Ronal wheels?
Posted: Mon Jan 17, 2011 1:53 pm
by Melvivio
Thanks!
Yes it are ronal wheels! the.. teledails, or A1 is the correct name.
Swapping the engine in isn't as easy as it would seem. Alot of sensors have to be cut off, you need to make a fitting for the heater unit, reweld the oilpump sucktube
But there can't be enough great gtv's in the world, so in my opinion, go for it!
