could anybody advise me on the most convenient way of increasing the diameter of the intakes & plenum to suit a 3.0l motor which is in the car.(the car has the original 2.5 intake system)
ps the GTV was a 3.3 L with 6 carbs before i fitted the fuel injected 3.0L
- junglejustice
2.5 and 3.0 intake plenums and intake runners use exact same diameter IDs... Some plenums have 6 little "short-stack" pipes that actually stand-up inside te plenum - not good - later Milano/75 types were flush and radiused inside the plenum - good! BUT - they are all 34mm ID in diam...
Call me - I have some 50mm converted intake plenums and new 50mm cast aluminium intake runners for you...
- Mezevenf
junglejustice wrote:I have some 50mm converted intake plenums and new 50mm cast aluminium intake runners for you...
1985 GTV6 2.5L 12v V6 - Red
1999 166 3.0L 24v V6 - Red
NightSpec
NightSpec
