Water Injection System reviewed
I am removing this post to make some improvements to it.
- Mezevenf
Holy crap!
That must be a real PITA to work on at times! But I suppose its worth it ey?
I like the color coordination.
1985 GTV6 2.5L 12v V6 - Red
1999 166 3.0L 24v V6 - Red
NightSpec
NightSpec
It's actually easy to work on. I loosen two clamps and the whole supercharger intake system comes off. Two more clamps and the discharge pipe comes off. Once that's done everything is just as easy to get to as the stock setup. Actually the oil filter is a lot easier because the stock air box is not in the way.
It's soooo worth it. I don't want to discuss the amount of boost I am getting away with on a stock engine and pump gas. Nor do I want to speculate on power until I have dyno results. Last time I did that I took an incredible amount of crap. However I will say that I am very very happy right now.
Haha, funny you mentioned that Pancho. It's not exactly the big red car, but his name is Greg (as in Greg from the Wiggles).
www.thewiggles.com.au
