Intake runners,length and diamater!!
Posted: Mon May 15, 2006 3:54 am
Guy's,
what effect does the lengthening or shortening,and increasing the size of the intake runners have ?
Reason i ask is i am trying to decide what to do with the 3l i am putting in my gtv6,the 3l came from a 164,and has the longer rounded runners. as you know the plenum and runners need some modification to fit in a gtv6 engine bay.
i was thinking of turning the runners around 180 degrees and run the plenum done the passengers side head(RHD CAR).But the throttle body and the end of the plenum interfere with the cam pulley.so to get around this i thought about making the runners "run" further down the rocker cover(extend them about 100mm).
or put the plenum on the passengers side as above but instead of extending the runners,cut the end of the plenum and weld it back on at a different angle to clear the cam wheel .
i'll try to post some pic's to help show what i mean .
any help please
CHEERS ALL
FLETCH....
any help please
CHEERS ALL
FLETCH....
