KingDom
2 litre cylinder liner
Post by KingDom »
Does anyone know what material the cylinder liner is made of on the 2 litre engines? grey cast, nodular iron, ductile iron?
Is there a better alternative to the standard item?
I have heard of several modified high power engines having a liner split from detonation.
Dom
patzo_3l
Post by patzo_3l »
monobarrells.....monobarrells is that what your after?
patzo_3l
3l gtv6 turbo 85'
2006 147 gta selespeed
1990 75 twinspark
1998 spider
2.0l gtv 85'
33 1.7ie
I think he just wants to know if there is a better version of the std liners available.
benski105
liners
Post by benski105 »
from what iv heard, you can get better quality liners for more performance engines.
i know of someone who bought some from paul spruell in the US. they were 85mm and are apparently better quality than standard
try www.paulspruell.com
hope this helps
ben
1962 Giulia Ti Race-car
1969 Giulia Super
1987 GTV6- new race project.
Benininca has some but the prices are not in my league.
KingDom, Beninca mono block 3k. Good for 700hp+ and proven to be such.
400hp is achieveable without running into too many issues. If youre gonna be pushin that much boost and rpm into an alfa 2.0 or TS, then the liners are the last of your problem!
You may have seen the silver alfetta gt at the sydney concourse over the last few years with a 1.8T engine in it- 330rwhp on stock liners.
It is a streetcar though, so if youre gonna build a weapon racer, that will spend its life living above 5k rpm with 20psi+ boost being rammed down its throat, the monoblock is the way to go.
DOnt curse and say "Damned alfas", because SR20s need them too, and so do Hondas.
Ah, a pleasure indeed to see you back Big Julie. :D
Here and there, and whenever I get a chance, I will be back with random comments, until I have the cash to make some more creative input!!!
Im still recuperating from the shock of driving your schmick car MD.... it has me thinking about whether I should strip mine out and race it, or save the engine for a 3.4L conversion into a 105 for a summernats style show car.... oooooh I need a job!
Speaking of which, anyone know what the new 2.2 engines are like crank rod and block wise? Fark me a hairdrier on one of those would make for some torque and hp!!!
