I may need to change my injectors and I want to go for an aftermarket upgrade.
What ref do I need to look for?
Any experience ?
Injectors for 2,0 TS
75 TS Road specs
75 TS Gr N
146 TS
I don't understand.
The injectors themself won't do you any good. Only if you tune the engine beyond the capacity of the OE injectors (about 170 hp) you need new ones. Then they must be matched to the power you plan and the software adjusted accordingly.
We use Accel injectors of 300 cc/min which are OK up to about 240 hp.
That´s what I was looking for...the HP limit for these OEM injectors.
My TS has some improvements like CAI, remapped ECU and custom exhaust but I´m sure I haven´t even reached 165hp...
So I´ll stick with OEM injectors and maybe later I will be back to ask you about Accel items.
Maybe when I´ll fit some C&B cams...
Thanks Micke
Thanks Micke
75 TS Road specs
75 TS Gr N
146 TS
dunno if you may be interested but i have new old stock twinspark injecteres on the shelf. brand new and rubbers and everything are all in excellent condition. doing some spring cleaning so if you were interested would let them go real cheap. pm me.
patzo_3l
3l gtv6 turbo 85'
2006 147 gta selespeed
1990 75 twinspark
1998 spider
2.0l gtv 85'
33 1.7ie
3l gtv6 turbo 85'
1990 75 twinspark
1998 spider
2.0l gtv 85'
33 1.7ie
