Page 1 of 3
Headers for long duration/high lift race cams
Posted: Sun Jan 14, 2007 7:42 am
by Jarle
Hi folks.
I have been watching the discussion about headers for the 3l V6 12 v engines. As the products available are few I decided to build my own manifoil. I considered to buy the CSCs but I can not get any software or calculations to make up for the lenght of the CSCs. They produse good power in low/mid but I can not get the big horsepower with them(simulations).
Any comments/experince?
Thanks
Jarle
Posted: Sun Jan 14, 2007 11:52 am
Looks very good! Primary length?
Posted: Sun Jan 14, 2007 2:25 pm
by Greg Gordon
Wow Jarle, those look fantastic.
Posted: Sun Jan 14, 2007 2:58 pm
by Zamani
WOW! Primary size and length?
And those intake ports look huge!
Posted: Mon Jan 15, 2007 12:33 am
by tImBoWe
Very cool! Where would you expect the power/torque peak to be with that length of primary? Any other mods?
Posted: Mon Jan 15, 2007 8:34 am
by Jarle
Thanks. Primarys are 28", OD 1 5/8. Have eksperimented with larger OD but it has a bad effect over hte whole powerband exept above 6500rpm.
tImBoWe: other mods are custom intake with larger intake ports and ITBs from Suzuki GSXR, much lift and duration, high compression pistons, pulleys flywheels and camsprockets in very light alloy, and lots of other changes.
Expect peak torque at 5200-5400prm, and peak power at 6400-6600rpm. The power curve should pass the std V6 curve at about 3800-4000rpms.
Jarle
Posted: Mon Jan 15, 2007 12:40 pm
by Zamani
Jarle,
Didn't you make a set which looked very similar to the CSC except with bigger primaries?
BTW, do you have a jig? How about making a few sets for us here
. No real welding needed, I mean just a few tack welds. That's all we need.
Posted: Mon Jan 15, 2007 7:44 pm
by sira
It look very cool, now you can put two turbo's on that headers
Posted: Tue Jan 16, 2007 1:27 pm
by Zamani
Is collector shape important?
Posted: Wed Jan 17, 2007 12:43 pm
by TS_turbo
merge type collector with ventury is best you can have
http://www.burnsstainless.com/MergeColl ... ctors.html
Posted: Wed Jan 17, 2007 2:49 pm
by Zamani
Yes, I have burnstainless collector where the 2 secondary pipes merge. But I was hoping to avoid it with 2 X 3-into-1 collectors. They'll cost about $500!!!
I found cheaper formed 3-into-1 collectors, but I don't know if it is a smart compromise... the formed collectors are only $8 each
Posted: Thu Jan 18, 2007 7:08 am
by Jarle
Zamani: yes i built a copy of the CSCs for another engine setup.
I get the bends from
www.stahlheaders.com Got a large package from them weighing just above 30 kilograms, and that is expensive to ship to Norway. Then adding the cost of the bends with the time it takes to build the headers and shipment back to the US it wont be cheap
With these nice bends you can make your own system with just a simple "metall saw" and a welder, no big challenge.
Use the stahlheaders 3-1 collectors. I am not an expert at this, but my oppinion is that it has minor importance weather you use a reasonable designed merge/baffle collector.To put it another way, you will never make big horsepower with badly tuned primarys and a good collector. But there is a good chance of making good power with tuned primarys and a "bad" collector.
Posted: Thu Jan 18, 2007 8:28 am
by Zamani
Thanks for the info Jarle. BTW what do you recommend, 18 gauge thick pipes or 16 gauge? I think 16 would be better for heat retention and strength.
Posted: Thu Jan 18, 2007 10:02 am
by Jarle
Zamani: Agree, for a daily driven street car 16 guage should be just fine. I use 18 guage only to save weight.
Right now I am designing new ultra light mufflers, with 20 guage inner cores and very thinn alu body. These can be taken apart and overhaul in 2 minutes.
Posted: Thu Jan 18, 2007 11:32 pm
Jarle
A big pat on the back for having a go !
One tiny bit of advice to help you along. Using aluminium for exhaust components could be a problem of short life. The reason is that all fuels have some amount of sulphur in them and when the gases reach their "DEW POINT", they will form sulphuric acid. This will strongly react with the aluminium to munch holes in your fabrications.
Try a little experiment. Get some sulphuric acid and introduce some aluminium into it (taking all necessary personal protection first of course). Observe what happens to it. The same will happen to your components but at a slower rate.
Your call..
