Undecided Performance Direction
Posted: Sat Mar 28, 2009 4:54 pm
I'm wanting more performance from my 3ltr 75 Potenziata and I'm really undecided as which way to go about it.
My decision is whether to stay NA and port heads, fit decent cams, modify the plenum chamber and make a set of exstractors.
Or go a standard compression (9.5:1) low boost turbo set up.
NA will allow me to keep that sexy Italian V6 note and better go, but a well done turbo will give that broad smooth torque the I get from my other 2 cars (well not the Silvia ATM).
The whole intentions are to do as much of the work myself. I even machined some pipes to make the collectors for a set of extractors before I started to seriously ponder the option of low boost turboing.
I've been doing as much research as I can on porting cylinder heads and even how to build a flow bench.
Camshafts seem to be a touchy subject, but Richard Jameson seems to really know his stuff. If I went cams then I'd be looking at what he offers very closely.
If I went turbo, it is intended to use a smallish 1, probably a late model Nissan or a newish Garrett, which ever 1 I can find on evil pay for the best price that most suits my desired outcome (performance versus $$$).
Any fabrication or porting work will be done by me. The whole idea is decent performance gain per dollar spent, baring in mind that this is a road car, so it needs to be reliable and still offer excellent road manners and return respectable fuel ecconomy when cruising on the highway.
Some people may think I'm beeing some sort of unrealistic dreamer, but I know that excellent performance increases can be achieved when you use your head and can design and make things that are functional and well built.
For the reccord, the issue of engine management is intended to be overcome by using the complete system from the local '86-'88 model Holden Commodore. These are a Nissan system and because they are quite simple and well supported in the aftermarket http://www.nistune.com/, I should be able to have an easilly reprogrammed manufacturer quallity system for minimal dollars. I've also got some experiance with Nissan electrics and there's heaps of stuff on the 'net.
Thoughts and opinions, please.
