Quaife for Transaxle
I'm new to this forum, but am very interested in the prospect of obtaining Quaife diffs. I own some auto repair shops in St. Louis , MO, including an Alfa/Exotic/Race car repair shop, and I race a GTV-6 with a LSD transaxle. The Quaife has many advantages. I'll commit to 3 - 4 units right now. I'm sure I can move more units also, as the price is great - about wholesale. I've installed several Quaife units on other types of cars, and the going price (part only) is $1,100 - $1,300. Install is a snap.
Bob Volpe, volpebob2@aol.com
- junglejustice
A new twist in getting power down. I beleive there are advantages over a disc driven LSD.
Try..
http://www.importperformance.com/quaife/
They are pretty hot wth the import crowd. Also gaining popularity with other machinary. Expensive though when you could get a decent Milano transaxle with an LSD.
Try..
Jef
www.motozane.com
www.motozane.com
jj: It's a variation of a Torsen diff.
There's been talk of group buys before but to get 30 guys to couch up that quite big stack of bills is not really easy.
Talking to the crowd over here I'm not convinced that the gain is more then marginal over a prepped stock LSD.
What about Gripper? They list Alfa transaxles as a application and they let you choose ramp angles and such, sounds better to me cause we can buy then one at a time if we want.
There's been more than enough talk about the Quaife LSD in the recent past. It is WAY better than the std factory LSD even when this last one is correctly adjusted, as the Quaife DOES NOT WEAR or require readjustment! You install it and that's the last time you'll need to see it (unless you break something). The factory ZF NEEDS regular readjustment.How often, depends on actual use and TYPE of use.It starts to wear as soon as you turn the first corner. Its not easy to set the correct preload,it may take from one to several hours, ACTUAL diff work (without the removal and refitting process which is another good hour and a half to two hours in itself) depending on how lucky you are as you're working with clearances in the order of .01 to .02mm. You can see that the slightest wear will change the clearance! The LSD still WORKS, but you can definitely feel the difference, at least in the track! Just ask Ron Simons! I adjusted 3 diffs for 47% lockout last time I was there and the man was impressed at the way the cars behaved in the 'Ring. Two months later he notices the deterioration, which means that readjusment is again required!! You all understand that we can't make a hobby of adjusting these things on a regular basis. The next bigger ZF LSD as fitted to some big BMW's contains a stiff spring disc, which maintains the preload for a MUCH longer time than our diffs.It's a simple yet ingenious solution which CAN also be adopted in our case by someone with enough know-how. Why not forget about all this then and get a Quaife? At this point, I will renew my plea for a group order and put myself down for at least 2 units. What apparently has to be worked out, is HOW we can send a collective down payment to Quaife to get things rolling. Maybe interested members can start a thread and take it from there?
Regards,
Regards,
But how many that have a LSD now hav actually had a problem with it?
What I mean is, does anyone of you have a problem with the inside wheel spinning due to a worn LSD?
You might want to check your suspension geometry first before buying a VERY expensive diff. Cure the cause and not the symptom.
- junglejustice
Well,
And then there is Phantom Grip - that is also making good headlines....
A different pricipal than Torson, but an "LSD"-like "fix" if you will....
Has anyone gotten a quote from Quaife on their LSD for the Alfa transaxle? Does anyone have the contact person within Quaife who provided the quote?
- junglejustice
HEY JESS!!!
Welcome to the party... I see you made it....
- Dennis
The minimum quantity would be 30 pcs and they would cost around 1000 euros a piece. I've heard it's great but never driven a car with one myself. I've sent a diff to them (and got it back) but for me it's too much of a risk to be responsible for 30 pcs.
'81 GTV6 3.0 QV
'91 75 TS (track)
'02 BMW 330i Touring
'91 75 TS (track)
We discussed this issue both on "this forum" as well as offline and at our gettogether by the ring.
1 k€ is about affordable. If I didn't have a LSD I'd go for it immediately. If there's a group buy I'll still consider it.
However, I don't believe the car will be much faster. I'm with Mats that the OE unit works pretty well. I do not have any problems at all. I didn't even tune it like Jim suggested. That will be my next step.
About the wear of the Quaiffes I only have one experience.
The last race I did we had a FWD with a Quaiffe. It worked like a dream for the practise, qualifying and 25% of the race. After this there was NO LSD at all. I don't know what happened and didn't talk to the team since. Probably the unit broke totally. This was the first race with the unit. Expensive km's.
According to the Quaife link above the LSD comes with some form of limited lifetime warranty, even when raced.
If the Quaife LSD is as good as it appears, I would also be interested. Though, the logistics of a group buy across multiple continents appears daunting...
A side note: The application list actually lists one for 164 and 155 - $1295.
Hi everybody, my laptop at home went 'belly-up' yesterday, so if anyone is trying to send me something, please use my office address: dkartalamakis@haicorp.com I will let you know when you can revert to the jkv6... again. Thanks for the use of this space for the contingency!
Regards,
PS: Since it looks like all my data may be lost following eventual
formatting, can the members who have written to me in the
past drop me a line with their addresses?
Regards,
