Do GTV6 wheels (Speedlines) fit on Alfa 164s?
Thanks!
Re: Do GTV6 Wheels Fit on Alfa 164s?
sort of - the PCD is the same, so you 'can' physically bolt them on, but the centre bore on the 164 is smaller so the gtv6 rims will not locate properly, which can lead to nasty vibrations/broken bolts/missing wheels/tears before bedtime.
Jason
1983 GTV6 2.8 litre
1983 GTV6 2.8 litre
