I have taken measurements of the position of the screws on the carter and the interior walls.
If someone needs to do his separator, here it is:
Code: Select all
ISO-10303-21;
HEADER;
FILE_DESCRIPTION(('CATIA V5 STEP Exchange'),'2;1');
FILE_NAME('C:\\Documents and Settings\\Ana\\My Documents\\Part1.stp','2015-06-11T23:27:51+00:00',('none'),('none'),'CATIA Version 5 Release 21 GA (IN-10)','CATIA V5 STEP AP203','none');
FILE_SCHEMA(('CONFIG_CONTROL_DESIGN'));
ENDSEC;
/* file written by CATIA V5R21 */
DATA;
#5=PRODUCT('Part1','','',(#2)) ;
#1=APPLICATION_CONTEXT('configuration controlled 3D design of mechanical parts and assemblies') ;
#14=PRODUCT_DEFINITION('',' ',#6,#3) ;
#16=SECURITY_CLASSIFICATION(' ',' ',#15) ;
#15=SECURITY_CLASSIFICATION_LEVEL('unclassified') ;
#47=CARTESIAN_POINT(' ',(0.,0.,0.)) ;
#51=CARTESIAN_POINT('Point.1',(11.431,-15.149,0.)) ;
#55=CARTESIAN_POINT('Point.2',(6.733,-83.493,0.)) ;
#56=CARTESIAN_POINT('Point.3',(9.832,-153.359,0.)) ;
#57=CARTESIAN_POINT('Point.4',(12.873,-223.15,0.)) ;
#58=CARTESIAN_POINT('Point.5',(16.938,-278.829,0.)) ;
#59=CARTESIAN_POINT('Point.6',(65.531,-300.395,0.)) ;
#60=CARTESIAN_POINT('Point.7',(134.298,-310.412,0.)) ;
#61=CARTESIAN_POINT('Point.8',(203.934,-305.395,0.)) ;
#62=CARTESIAN_POINT('Point.10',(270.477,-285.772,0.)) ;
#63=CARTESIAN_POINT('Point.11',(327.779,-245.886,0.)) ;
#64=CARTESIAN_POINT('Point.12',(324.761,-196.004,0.)) ;
#65=CARTESIAN_POINT('Point.13',(321.81,-106.095,0.)) ;
#66=CARTESIAN_POINT('Point.14',(318.842,-36.36,0.)) ;
#67=CARTESIAN_POINT('Point.15',(286.029,17.381,0.)) ;
#68=CARTESIAN_POINT('Point.16',(216.232,12.345,0.)) ;
#69=CARTESIAN_POINT('Point.17',(146.515,7.234,0.)) ;
#70=CARTESIAN_POINT('Point.18',(76.738,2.685,0.)) ;
#71=CARTESIAN_POINT('Point.19',(0.,0.,0.)) ;
#72=CARTESIAN_POINT('Point.20',(12.591,-298.109,0.)) ;
#73=CARTESIAN_POINT('Point.21',(120.087,-318.665,0.)) ;
#74=CARTESIAN_POINT('Point.22',(217.784,-311.659,0.)) ;
#75=CARTESIAN_POINT('Point.23',(331.635,-272.64,0.)) ;
#76=CARTESIAN_POINT('Point.24',(319.122,22.782,0.)) ;
#77=CARTESIAN_POINT('Point.25',(47.563,-227.399,0.)) ;
#78=CARTESIAN_POINT('Point.26',(33.481,-49.454,0.)) ;
#79=CARTESIAN_POINT('Point.27',(85.791,-45.804,0.)) ;
#80=CARTESIAN_POINT('Point.28',(94.776,-176.165,0.)) ;
#81=CARTESIAN_POINT('Point.29',(154.407,-173.584,0.)) ;
#82=CARTESIAN_POINT('Line Origine',(47.563,-227.399,0.)) ;
#86=CARTESIAN_POINT('Limit',(47.563,-227.399,0.)) ;
#87=CARTESIAN_POINT('Limit',(33.481,-49.454,0.)) ;
#91=CARTESIAN_POINT('Line Origine',(33.481,-49.454,0.)) ;
#95=CARTESIAN_POINT('Limit',(33.481,-49.454,0.)) ;
#96=CARTESIAN_POINT('Limit',(85.791,-45.804,0.)) ;
#100=CARTESIAN_POINT('Line Origine',(85.791,-45.804,0.)) ;
#104=CARTESIAN_POINT('Limit',(85.791,-45.804,0.)) ;
#105=CARTESIAN_POINT('Limit',(94.776,-176.165,0.)) ;
#109=CARTESIAN_POINT('Line Origine',(94.776,-176.165,0.)) ;
#113=CARTESIAN_POINT('Limit',(94.776,-176.165,0.)) ;
#114=CARTESIAN_POINT('Limit',(154.407,-173.584,0.)) ;
#118=CARTESIAN_POINT('Line Origine',(0.,0.,0.)) ;
#122=CARTESIAN_POINT('Limit',(0.,0.,0.)) ;
#123=CARTESIAN_POINT('Limit',(12.591,-298.109,0.)) ;
#127=CARTESIAN_POINT('Line Origine',(12.591,-298.109,0.)) ;
#131=CARTESIAN_POINT('Limit',(12.591,-298.109,0.)) ;
#132=CARTESIAN_POINT('Limit',(120.087,-318.665,0.)) ;
#136=CARTESIAN_POINT('Line Origine',(120.087,-318.665,0.)) ;
#140=CARTESIAN_POINT('Limit',(120.087,-318.665,0.)) ;
#141=CARTESIAN_POINT('Limit',(217.784,-311.659,0.)) ;
#145=CARTESIAN_POINT('Line Origine',(217.784,-311.659,0.)) ;
#149=CARTESIAN_POINT('Limit',(217.784,-311.659,0.)) ;
#150=CARTESIAN_POINT('Limit',(331.635,-272.64,0.)) ;
#154=CARTESIAN_POINT('Line Origine',(331.635,-272.64,0.)) ;
#158=CARTESIAN_POINT('Limit',(331.635,-272.64,0.)) ;
#159=CARTESIAN_POINT('Limit',(319.122,22.782,0.)) ;
#163=CARTESIAN_POINT('Line Origine',(319.122,22.782,0.)) ;
#167=CARTESIAN_POINT('Limit',(319.122,22.782,0.)) ;
#168=CARTESIAN_POINT('Limit',(0.,3.5527136788E-015,0.)) ;
#172=CARTESIAN_POINT('Point.30',(277.268,-210.859,0.)) ;
#173=CARTESIAN_POINT('Point.31',(266.175,-33.33,0.)) ;
#174=CARTESIAN_POINT('Point.32',(213.873,-36.857,0.)) ;
#175=CARTESIAN_POINT('Point.33',(223.285,-167.329,0.)) ;
#176=CARTESIAN_POINT('Point.34',(164.29,-173.526,0.)) ;
#177=CARTESIAN_POINT('Line Origine',(277.268,-210.859,0.)) ;
#181=CARTESIAN_POINT('Limit',(277.268,-210.859,0.)) ;
#182=CARTESIAN_POINT('Limit',(266.175,-33.33,0.)) ;
#186=CARTESIAN_POINT('Line Origine',(266.175,-33.33,0.)) ;
#190=CARTESIAN_POINT('Limit',(266.175,-33.33,0.)) ;
#191=CARTESIAN_POINT('Limit',(213.873,-36.857,0.)) ;
#195=CARTESIAN_POINT('Line Origine',(213.873,-36.857,0.)) ;
#199=CARTESIAN_POINT('Limit',(213.873,-36.857,0.)) ;
#200=CARTESIAN_POINT('Limit',(223.285,-167.329,0.)) ;
#204=CARTESIAN_POINT('Line Origine',(223.285,-167.329,0.)) ;
#208=CARTESIAN_POINT('Limit',(223.285,-167.329,0.)) ;
#209=CARTESIAN_POINT('Limit',(164.29,-173.526,0.)) ;
#213=CARTESIAN_POINT('Point.35',(64.543,-114.539,0.)) ;
#214=CARTESIAN_POINT('Point.36',(77.161,-310.348,0.)) ;
#215=CARTESIAN_POINT('Line Origine',(64.543,-114.539,0.)) ;
#219=CARTESIAN_POINT('Limit',(64.543,-114.539,0.)) ;
#220=CARTESIAN_POINT('Limit',(77.161,-310.348,0.)) ;
#224=CARTESIAN_POINT('Point.37',(243.399,-100.89,0.)) ;
#225=CARTESIAN_POINT('Point.38',(259.924,-297.138,0.)) ;
#226=CARTESIAN_POINT('Line Origine',(243.399,-100.89,0.)) ;
#230=CARTESIAN_POINT('Limit',(243.399,-100.89,0.)) ;
#231=CARTESIAN_POINT('Limit',(259.924,-297.138,0.)) ;
#235=CARTESIAN_POINT('Point.39',(147.538,-123.449,0.)) ;
#236=CARTESIAN_POINT('Point.40',(158.531,-279.154,0.)) ;
#83=DIRECTION('Vector Direction',(-0.0788901673332,0.996883313883,0.)) ;
#92=DIRECTION('Vector Direction',(0.99757448496,0.0696070898509,0.)) ;
#101=DIRECTION('Vector Direction',(0.0687608567332,-0.997633171352,0.)) ;
#110=DIRECTION('Vector Direction',(0.999064611245,0.0432423699355,0.)) ;
#119=DIRECTION('Vector Direction',(0.0421986067743,-0.999109242068,0.)) ;
#128=DIRECTION('Vector Direction',(0.982202992311,-0.187822474417,0.)) ;
#137=DIRECTION('Vector Direction',(0.997438604062,0.0715278346322,0.)) ;
#146=DIRECTION('Vector Direction',(0.945985778218,0.324208123603,0.)) ;
#155=DIRECTION('Vector Direction',(-0.0423184141247,0.999104174661,0.)) ;
#164=DIRECTION('Vector Direction',(-0.997461459802,-0.0712083998509,0.)) ;
#178=DIRECTION('Vector Direction',(-0.0623639360391,0.998053475262,0.)) ;
#187=DIRECTION('Vector Direction',(-0.997733967219,-0.0672824691672,0.)) ;
#196=DIRECTION('Vector Direction',(0.071951112887,-0.99740815986,0.)) ;
#205=DIRECTION('Vector Direction',(-0.994528245117,-0.104468031782,0.)) ;
#216=DIRECTION('Vector Direction',(0.0643069665894,-0.997930164915,0.)) ;
#227=DIRECTION('Vector Direction',(0.0839077343521,-0.996473528056,0.)) ;
#48=AXIS2_PLACEMENT_3D(' ',#47,$,$) ;
#40=PRODUCT_DEFINITION_SHAPE(' ',' ',#14) ;
#90=COMPOSITE_CURVE('Line.1',(#89),.U.) ;
#99=COMPOSITE_CURVE('Line.2',(#98),.U.) ;
#108=COMPOSITE_CURVE('Line.3',(#107),.U.) ;
#117=COMPOSITE_CURVE('Line.4',(#116),.U.) ;
#126=COMPOSITE_CURVE('Line.5',(#125),.U.) ;
#135=COMPOSITE_CURVE('Line.6',(#134),.U.) ;
#144=COMPOSITE_CURVE('Line.7',(#143),.U.) ;
#153=COMPOSITE_CURVE('Line.8',(#152),.U.) ;
#162=COMPOSITE_CURVE('Line.9',(#161),.U.) ;
#171=COMPOSITE_CURVE('Line.10',(#170),.U.) ;
#185=COMPOSITE_CURVE('Line.11',(#184),.U.) ;
#194=COMPOSITE_CURVE('Line.12',(#193),.U.) ;
#203=COMPOSITE_CURVE('Line.13',(#202),.U.) ;
#212=COMPOSITE_CURVE('Line.14',(#211),.U.) ;
#223=COMPOSITE_CURVE('Line.15',(#222),.U.) ;
#234=COMPOSITE_CURVE('Line.16',(#233),.U.) ;
#89=COMPOSITE_CURVE_SEGMENT(.DISCONTINUOUS.,.T.,#88) ;
#98=COMPOSITE_CURVE_SEGMENT(.DISCONTINUOUS.,.T.,#97) ;
#107=COMPOSITE_CURVE_SEGMENT(.DISCONTINUOUS.,.T.,#106) ;
#116=COMPOSITE_CURVE_SEGMENT(.DISCONTINUOUS.,.T.,#115) ;
#125=COMPOSITE_CURVE_SEGMENT(.DISCONTINUOUS.,.T.,#124) ;
#134=COMPOSITE_CURVE_SEGMENT(.DISCONTINUOUS.,.T.,#133) ;
#143=COMPOSITE_CURVE_SEGMENT(.DISCONTINUOUS.,.T.,#142) ;
#152=COMPOSITE_CURVE_SEGMENT(.DISCONTINUOUS.,.T.,#151) ;
#161=COMPOSITE_CURVE_SEGMENT(.DISCONTINUOUS.,.T.,#160) ;
#170=COMPOSITE_CURVE_SEGMENT(.DISCONTINUOUS.,.T.,#169) ;
#184=COMPOSITE_CURVE_SEGMENT(.DISCONTINUOUS.,.T.,#183) ;
#193=COMPOSITE_CURVE_SEGMENT(.DISCONTINUOUS.,.T.,#192) ;
#202=COMPOSITE_CURVE_SEGMENT(.DISCONTINUOUS.,.T.,#201) ;
#211=COMPOSITE_CURVE_SEGMENT(.DISCONTINUOUS.,.T.,#210) ;
#222=COMPOSITE_CURVE_SEGMENT(.DISCONTINUOUS.,.T.,#221) ;
#233=COMPOSITE_CURVE_SEGMENT(.DISCONTINUOUS.,.T.,#232) ;
#31=APPROVAL_PERSON_ORGANIZATION(#25,#21,#19) ;
#25=PERSON_AND_ORGANIZATION(#22,#23) ;
#22=PERSON(' ',' ',' ',$,$,$) ;
#23=ORGANIZATION(' ',' ',' ') ;
#21=APPROVAL(#20,' ') ;
#20=APPROVAL_STATUS('not_yet_approved') ;
#19=APPROVAL_ROLE('APPROVER') ;
#13=DATE_AND_TIME(#11,#12) ;
#12=LOCAL_TIME(1,27,22.,#10) ;
#10=COORDINATED_UNIVERSAL_TIME_OFFSET(0,0,.AHEAD.) ;
#84=VECTOR('Line Direction',#83,1.) ;
#93=VECTOR('Line Direction',#92,1.) ;
#102=VECTOR('Line Direction',#101,1.) ;
#111=VECTOR('Line Direction',#110,1.) ;
#120=VECTOR('Line Direction',#119,1.) ;
#129=VECTOR('Line Direction',#128,1.) ;
#138=VECTOR('Line Direction',#137,1.) ;
#147=VECTOR('Line Direction',#146,1.) ;
#156=VECTOR('Line Direction',#155,1.) ;
#165=VECTOR('Line Direction',#164,1.) ;
#179=VECTOR('Line Direction',#178,1.) ;
#188=VECTOR('Line Direction',#187,1.) ;
#197=VECTOR('Line Direction',#196,1.) ;
#206=VECTOR('Line Direction',#205,1.) ;
#217=VECTOR('Line Direction',#216,1.) ;
#228=VECTOR('Line Direction',#227,1.) ;
#49=SHAPE_REPRESENTATION(' ',(#48),#46) ;
#4=APPLICATION_PROTOCOL_DEFINITION('international standard','config_control_design',1994,#1) ;
#32=APPROVAL_DATE_TIME(#13,#21) ;
#11=CALENDAR_DATE(2015,12,6) ;
#30=CC_DESIGN_APPROVAL(#21,(#16,#6,#14)) ;
#18=CC_DESIGN_DATE_AND_TIME_ASSIGNMENT(#13,#17,(#16)) ;
#29=CC_DESIGN_DATE_AND_TIME_ASSIGNMENT(#13,#28,(#14)) ;
#17=DATE_TIME_ROLE('classification_date') ;
#28=DATE_TIME_ROLE('creation_date') ;
#27=CC_DESIGN_PERSON_AND_ORGANIZATION_ASSIGNMENT(#25,#26,(#16)) ;
#33=CC_DESIGN_PERSON_AND_ORGANIZATION_ASSIGNMENT(#25,#34,(#6)) ;
#35=CC_DESIGN_PERSON_AND_ORGANIZATION_ASSIGNMENT(#25,#36,(#6,#14)) ;
#37=CC_DESIGN_PERSON_AND_ORGANIZATION_ASSIGNMENT(#25,#38,(#5)) ;
#26=PERSON_AND_ORGANIZATION_ROLE('classification_officer') ;
#34=PERSON_AND_ORGANIZATION_ROLE('design_supplier') ;
#36=PERSON_AND_ORGANIZATION_ROLE('creator') ;
#38=PERSON_AND_ORGANIZATION_ROLE('design_owner') ;
#39=CC_DESIGN_SECURITY_CLASSIFICATION(#16,(#6)) ;
#54=SHAPE_REPRESENTATION_RELATIONSHIP(' ',' ',#49,#52) ;
#3=DESIGN_CONTEXT(' ',#1,'design') ;
#53=GEOMETRIC_SET('NONE',(#51,#55,#56,#57,#58,#59,#60,#61,#62,#63,#64,#65,#66,#67,#68,#69,#70,#71,#72,#73,#74,#75,#76,#77,#78,#79,#80,#81,#90,#99,#108,#117,#126,#135,#144,#153,#162,#171,#172,#173,#174,#175,#176,#185,#194,#203,#212,#213,#214,#223,#224,#225,#234,#235,#236)) ;
#52=GEOMETRICALLY_BOUNDED_SURFACE_SHAPE_REPRESENTATION('NONE',(#53),#46) ;
#45=UNCERTAINTY_MEASURE_WITH_UNIT(LENGTH_MEASURE(0.005),#41,'distance_accuracy_value','CONFUSED CURVE UNCERTAINTY') ;
#85=LINE('Line',#82,#84) ;
#94=LINE('Line',#91,#93) ;
#103=LINE('Line',#100,#102) ;
#112=LINE('Line',#109,#111) ;
#121=LINE('Line',#118,#120) ;
#130=LINE('Line',#127,#129) ;
#139=LINE('Line',#136,#138) ;
#148=LINE('Line',#145,#147) ;
#157=LINE('Line',#154,#156) ;
#166=LINE('Line',#163,#165) ;
#180=LINE('Line',#177,#179) ;
#189=LINE('Line',#186,#188) ;
#198=LINE('Line',#195,#197) ;
#207=LINE('Line',#204,#206) ;
#218=LINE('Line',#215,#217) ;
#229=LINE('Line',#226,#228) ;
#2=MECHANICAL_CONTEXT(' ',#1,'mechanical') ;
#24=PERSONAL_ADDRESS(' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',(#22),' ') ;
#43=PLANE_ANGLE_MEASURE_WITH_UNIT(PLANE_ANGLE_MEASURE(0.0174532925199),#42) ;
#7=PRODUCT_CATEGORY('part',$) ;
#9=PRODUCT_CATEGORY_RELATIONSHIP(' ',' ',#7,#8) ;
#6=PRODUCT_DEFINITION_FORMATION_WITH_SPECIFIED_SOURCE('',' ',#5,.NOT_KNOWN.) ;
#8=PRODUCT_RELATED_PRODUCT_CATEGORY('detail',$,(#5)) ;
#50=SHAPE_DEFINITION_REPRESENTATION(#40,#49) ;
#88=TRIMMED_CURVE('',#85,(#86),(#87),.T.,.CARTESIAN.) ;
#97=TRIMMED_CURVE('',#94,(#95),(#96),.T.,.CARTESIAN.) ;
#106=TRIMMED_CURVE('',#103,(#104),(#105),.T.,.CARTESIAN.) ;
#115=TRIMMED_CURVE('',#112,(#113),(#114),.T.,.CARTESIAN.) ;
#124=TRIMMED_CURVE('',#121,(#122),(#123),.T.,.CARTESIAN.) ;
#133=TRIMMED_CURVE('',#130,(#131),(#132),.T.,.CARTESIAN.) ;
#142=TRIMMED_CURVE('',#139,(#140),(#141),.T.,.CARTESIAN.) ;
#151=TRIMMED_CURVE('',#148,(#149),(#150),.T.,.CARTESIAN.) ;
#160=TRIMMED_CURVE('',#157,(#158),(#159),.T.,.CARTESIAN.) ;
#169=TRIMMED_CURVE('',#166,(#167),(#168),.T.,.CARTESIAN.) ;
#183=TRIMMED_CURVE('',#180,(#181),(#182),.T.,.CARTESIAN.) ;
#192=TRIMMED_CURVE('',#189,(#190),(#191),.T.,.CARTESIAN.) ;
#201=TRIMMED_CURVE('',#198,(#199),(#200),.T.,.CARTESIAN.) ;
#210=TRIMMED_CURVE('',#207,(#208),(#209),.T.,.CARTESIAN.) ;
#221=TRIMMED_CURVE('',#218,(#219),(#220),.T.,.CARTESIAN.) ;
#232=TRIMMED_CURVE('',#229,(#230),(#231),.T.,.CARTESIAN.) ;
#41=(LENGTH_UNIT()NAMED_UNIT(*)SI_UNIT(.MILLI.,.METRE.)) ;
#42=(NAMED_UNIT(*)PLANE_ANGLE_UNIT()SI_UNIT($,.RADIAN.)) ;
#44=(NAMED_UNIT(*)SI_UNIT($,.STERADIAN.)SOLID_ANGLE_UNIT()) ;
#46=(GEOMETRIC_REPRESENTATION_CONTEXT(3)GLOBAL_UNCERTAINTY_ASSIGNED_CONTEXT((#45))GLOBAL_UNIT_ASSIGNED_CONTEXT((#41,#42,#44))REPRESENTATION_CONTEXT(' ',' ')) ;
ENDSEC;
END-ISO-10303-21;
(Starting at the top left corner, and counterclockwise.)
Radio1: X 47,789 Y -41,389 R=44,037
Radio2: X 51,478 Y -257,429 R=51,232
Radio3: X 274,158 Y -245,246 R=52,052
Radio4: X 283,228 Y -25,940 R=35,443
