I know that the details of the design are sure to be of the utmost importance. Since this is over my head I ask that everybody weigh in. Help design the headers.
I plan to order a small run (3-4 sets) to lower the unit cost, so perhaps a few others will be able to benifit if they turn out well.
What should my primary and secondary tubes measure, diameter and length? I have a stock engine right now, but I plan to open things up in the future with a Megasquirt and eventually a head rebuild.
I plan to use the CSC style (downpipes?) secondary pipes to keep clearance in check. What about up top? Do I use a design similar to Jarle, with the tubes going directly down, or do I make a more complex pretzel like the CSC design.
I would also like this to be able to fit without extreme modifications.
As everybody reading this can tell, I need some education here
Thanks in advance
