Well, stock - if you consider the GoTech ECU with the AFM removed, some headers, Dawie's 50mm intake plenum and 50mm cast aluminium intake runners....
If you recall; I had a catastrophic OEM wiring harness melt-down during Ron's visit here in July, so quite a bit of work went in to getting the dash R&R'ed, wiring replaced etc etc. Original thread - http://www.alfagtv6.com/bb/viewtopic.php?t=782
Any way, while I was at it, we added a TP100 ignition module - we are now firing the low impedance injectors correctly, so I had to do a bit of remapping as she was now running quite a bit richer. Gave it more timing advance too...
We also fitted a complete RSR kit as well as the new Group 2 Inc/GyroDisc 4-pot Wilwood fronts and reconditioned but spaced and vented rear brake setup with all-around aluminium floating hats and nickel-finished discs... The car feels so awesome now with Jes' steering wheel (
![Twisted Evil :twisted:](./images/smilies/icon_twisted.gif)
