What is the size of the hose from the fuel rail to the injectors on the 2.5 GTV6 engine?
I have to replace mine.
Greg, do you sell a kit for this?
Scott
Injector Fuel Hose
THis is from the Alfa Digest from a few years ago. The sourcec is Joe Elliott. My experience mirrors his in that the guys in BMW parts departments are not very helpful. He notes that their 8 x 13 is actually the proper 7.5MM
BMW Store: 1 meter (3.28ft), 13 31 1 469 781 "8x13" fuel hose, $10
AutoZone: 6ft (1.83m), 240844 65152 Goodyear 5/16" FI hose, $26.94
All these years, I'd been going to the BMW dealer to get the "good
stuff" only when I needed to make leak-free connections with OEM
barbed hose fittings on the fuel rail, and assumed I was saving money
by getting the locally-available 5/16" stuff (that works out to
7.94mm, while I believe "8x13" metric stuff is actually 7.5mm OD) for
all my other EFI work.
Scott Shure
Ellicott City, Md
85 GTV-6
Ellicott City, Md
85 GTV-6
Awww heck....went to the mercedes dealer to get it and paid almose 15 with tax for half a meter
Then I see your post
Took the fuel rail off last night....the hoses parted easily enough... and found the injectors loose and able to twiddle around
. fortunately I was able to find seal kits for $19 and change for all 6 injectors
They are Python Injection #200-120. The kits have upper and lower seals, the lower end cover and another plastic piece that I don't know what is.
So now I think I'm set to get the injectors back in and Greg's hose and intake kits on this weekend. And maybe rebuild the front end of the suspension.
Scott
Scott
