Greg that's correct.Don't be surprised if it cracks when you pull and twist because it takes quite a bit of force.Taking the AC belt off may make it a bit easier but getting that thing off is a battle in itself.Even with the tensioner fully slack you have to either pry the belt off the pully with a large screwdriver or loosen the mounting bolts for the AC compressor to get more slack - but don't go there
wow,
I finaly got the timming belt covers off. What a battle. I had to remove one of the colant sensors the top colant hose and the A/C belt. There's defintely a oil leak somewhere around there. It's going to be tricky to figure out where it's comming from. It looks like it might be coming from the crank seal.
So I've Done a second Compression test. And my results were very strange!! I first did a compression test on cyl. #1. It was about 105psi. This was better than the 30 psi i seemed to be getting for most cylinders last time. So i got a bit happy, but this feeling didn't last long. I checked #2 and i got no compression, #3 also no compression, #4 also no compression. I went back to number one and I no longer had compression. WTF? How is this possible? The only thing i can think is that, my starter is making some strange noises like a whining. Is it possible that it isn't spinning the engine fast enough for compression? The timming belt is rotating the cams, so i know the engine is turning over
I'm at a loss here!
I'm at a loss here!
- Que Boludo
Greg before you go any further what I would do is go to your local garage and borrow/rent a compression tester that is known to be accurate.I was once getting weird readings and my cheap tester turned out to be the problem.
ok guys,
here's the update.
i tried a new compression guage and still very low compression resulted.
2 days ago i had a 3 friends push start the car. After 2 runs the car fired up....it ran rough for a while, but now runs nice. I think the battery was not strong enough and not turning the engine over enough for a proper compression test. So It turns out i didn't have much of a problem. I'm thinking of changing my AAV. Has anyone installed the manual version, i think greg gordon was selling one.
thanks
Greg A
Toronto
here's the update.
thanks
Greg A
Toronto
