Reale
Fuel pump
Post by Reale »
By the way, if you are reading some kind of low voltage at the pump, 9 volts or less, the pump might be seized (I have had them do this before). It would be drawing current, but not turning.
Al Mitchell
Reale Motorsports
#82 E Production
Alfa Romeo GTV6
Sporttunergtv6
Post by Sporttunergtv6 »
so i did some rewiring... and now the car is back up and running. the fuel pump was not getting any juice so i ran some wires directly from the battery (w/ inline fuses) to the fuel pump... hooked it up to a switch and now i need to figure out why the fuel pump wasnt turning on. if i rotate those fuses one more time! i do not have my gtv6 owners manual. could somebody tell me if there is a relay on the fuse panel for the fuel pump and also what fuses i should check that deal with the fuel pump
