Situation:
-Cruising 4th gear at 4000rpm, and If I do full throttle(from 4000rpm), engine start making slight knocking.
-If I accelerate slowly, it is OK. Also, when I using 1st or 2nd or 3rd gear, it seems fine.
Engine:
3.0L Milano, New spark plugs & wires, new Distributor cap & roter, new coil(not bosch)
new dist vacuum advance.
I have checked ignition timing as STATIC: F mark. But, at 3000rpm, the timing is much more
than M mark. So, looks like ignition timing is too advanced at high rev.
I also tried changing ignition timing as 0.5 degree? BTDC *my timing light is cheap one, can't read
exact degree, the timing is, like 1mm from P (TDC) mark. It's work, much better than before, doesn't
make knocking mostly. Is it caused by Ignition advance ECU ? I am not sure which crank pulley
installed my engine (Milano or GTV6) but both F mark is 2 degree I think.
I might have some wrong information regarding the static ignition timing.
GTV6(2.5) ..... 2 deg BTDC
Milano(3.0)......7 deg BTDC
If so, my crack pulley could be Milano's. ......??
Crank pulley on my car
http://www015.upp.so-net.ne.jp/alfaromeo/5974.JPG
It looks like 7 or 8 degree from TDC(P)
Please let me know if it was Milano's? or any comment will help me.
Thanks in advance
Thanks in advance
Thanks for the info.Murray, and sorry to bothering all. It was my big mistake.
measured the crank diameter today, and calculated as follow.
The diametr of this crank pulley is 144 mm, the circumference of this pulley should be 358.14mm
2 degree = 1.98mm,
7 degree = 6.96mm
So, 2 degree on this pully is just about 2 mm from TDC(P) line......
I didn't doubt the pulley or static timing was different.
2 degree = 1.98mm,
7 degree = 6.96mm
