I've asked the question," What should I check for?",several times in the Alfabb and no ones been able to even suggest where to start.
Even though alot of you are the same Good guys in theBB,I'll give it another shot.
Here I go. My tach only revs up to 2000 RPM (and not even accuratly)
I've tried checking all the coil connections,and the connections behind the tach itself. Where else do I look?
I don't think that mine is the resistor,(located inside the tach.) because I have two milano verdes,and I took the tach out of the verde that has the working rpm ,and tried it on the one that dosen't work,and nothing.
I am determined to fix this damn thing.
All the problems I present to the BBers and other forums are quickly
tackled,this seems to be the only one,thats practicaly incurable
