Hi all.
I recently baught a mint second hand passanger door for my 83 Gtv6. The door came from and 85 same model. To my surprise when I took the door card off, I discovered a central locking solanoid. The plastic liner inside the door hadnt been touched, I had to remove it, hence I think the door is factory original. I didnt know the GTV6 had been sold with central locking. Was it? anyone know of any wiring diarams showing the circuit? Im sure it would be a doddle to wire up, the solanoids are standard FIAT units.
MJR
Mjr,I doubt very much if it was factory stock..The car in my avitar was fitted with central locking..
I used the frnt only from a Giulietta..It was a nice touch.Simply remove the whole harness and relay box unit and fit..Connect up supply 12v and earth or ground.Viola!! You now have central locking..
As an additional to mine,I isolated the switching circiut and fitted a switch to the door panel so I could lock/unlock at the press of a button.(which came from a BMW...)
