cold start solenoid
Posted: Wed Mar 29, 2006 7:54 am
I have been having a hard start problem with my 1986 GTV6 and have discovered that my cold start valve (7th injector) is not squirting gas with a cold motor. I tested it by pulling the injector out of the back of the manifold and cranking the motor. No gas. I have 3 cold start sensors and 2 injectors I have swapped out and no combination works, so it must be the wiring. I noticed that there must have been a problem at one time because the harness plug to the injector was replaced and has a crimp splice connection. two wires go in one side and one to the other.
Is there a way to check the wiring to see if I have a break in the wiring some where? This looks like a pretty simple circuit. I read that the L jet system cold start injector parts do not even pass through the L jet brain, so it's a stand alone circuit. What's the best way to trouble shoot?
Thanks
Doug
Thanks
Doug
