If you guys are rebuilding your alternators and need a few parts, check out:
http://www.wagneralt.com/lines/default.asp
Product catalog has slip rings, bearings, etc...for Bosch and others
More info on alternator parts:
same california store as above but you can put in the LESTER # and get all the components for your Bosch alternators. This is in their new "Visions" section:
http://www.wagneralt.com/visions
For example: I use BMW late 80's 90 amp alt...LESTER # '14813' typed in under part#...click on the LESTER part and the whole list of bearings, covers, slip rings, etc. pops up. You can get the LESTER# by calling or somehow through the site...
Real nice to deal with, too.
Example: (Pics did not show up here)
Number: 0-120-469-779
Description: ALTERNATOR
Manufacturer: BOSCH
Series: IR/EF
Rating: 90A
Voltage: 12V
Polarity: Neg
Rotation: CW
Regulator: INT
Fan: EXT
Pulley: 1 GRV
Wagner Bill of Materials
Description Qty Wagner Image
6201 2RS BEARING-12x32x10mm W02X-01
6303 2RS BEARING-17x47x14mm W02X-11
BO ALT BRUSH-5x8x19.5mm W030-02
BOSCH DIODE-NEG 35A 200V W04X-28
BOSCH DIODE-POS 35A 200V W04X-29
BO RECT-14396 AUDI,VW 90A W060-29
BO INT REG-28mm LOW PRO 14.7V W080-01H
BO INTERFERENCE CAPACITOR W110-04
BO ALT PULLEY HARDWARE W110-06N
BO BATTERY POST INSULATOR-BMW W110-17
BO PLASTIC BEARING RETAINER W110-21
BO SHAFT COLLAR-PRESS FIT W110-50
BOSCH BEARING RETAINER-6303 W110-58
BO SLIP RING-28mm W160-01
Corporate Office: 13352 Elliot Avenue, Chino California 91710 U.S.A.
Mailing Address: P.O. Box 2680, Chino Hills California 91709-0090 U.S.A.
Telephone: (800)345-5927 or (909)465-1950 Fax: (909)465-5032
E-Mail
© 2006 Wagner Alternators and Supplies, Inc. all rights reserved.
Manufacturer: BOSCH
Series: IR/EF
Rating: 90A
Voltage: 12V
Polarity: Neg
Rotation: CW
Regulator: INT
Fan: EXT
Pulley: 1 GRV
