86 GTV6 no start
Posted: Thu Nov 23, 2006 12:10 pm
Hi all,
I'm trying to revive an 86 GTV6 that has been sitting quite a while. So far we've cleaned all of the various ground and sensor connections and the motor spins over fine. Cleaned all of the fuses in the fuse block.
We cannot get power to the green/black wire to the coil nor can we get power to the fuel pump. I can hear (1) relay under the dash and one on the pass side fender well clicking on when I turn the key to on position. When the key is turned on there is power to the green/black wire at the main fuse box but not at the coil. We've even tried to replace the computer with another one of the same number but no go.
Any suggestions on what to ckech next? thanks.
