I'm having a tune up (ECU re-programming) done on my GTV6 3L. on a rolling-road-bench in a couple of weeks.
I'm currently running on stock Bosch Jetronic ECU (0 280 001 134) and it has a seperate black ignition box besides it.
When I'm having the ECU re-prog. I wan't the rev-limiter moved up a bit higher as it kicks in already @ 5688 rpm (right where the engine starts to sound really good
The engine is equipped with Shankle headers, C&B cams and heads has been ported, so I wanna get "as much" power out of the engine as possible from this setup, and DEFINATELY wan't the rev-limiter moved to @ least 6500 rpm. (But how "much" is recomendable? I don't wanna push things to far...
I'm also modifying the air flow with a AFM from a BMW 535i... We managed to adjust the BMW-AFM and make the engine run with it, but it clearly lacks fuel during driving. Hopefully a re-prog. of the ECU will fix that...
Maybe I should mention that the car runs with a Lambda but has no cat.
Can anybody guide me a little?
I've been reading quite a lot on this site but my knowledge isn't either good enough or I just miss some major points because of language-differences
All help is appreciated - thanx in advance
